Problème d'impression yoda June 18, 2013 09:09AM |
Re: Problème d'impression yoda June 18, 2013 09:20AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Problème d'impression yoda June 18, 2013 09:28AM |
/** \def STEPS_PER_M steps per meter ( = steps per mm * 1000 ) calculate these values appropriate for your machine for threaded rods, this is (steps motor per turn) / (pitch of the thread) * 1000 for belts, this is (steps per motor turn) / (number of gear teeth) / (belt module) * 1000 half-stepping doubles the number, quarter stepping requires * 4, etc. valid range = 20 to 4'0960'000 (0.02 to 40960 steps/mm) all numbers are integers, so no decimal point, please :-) */ #define STEPS_PER_M_X 10000 //10000 #define STEPS_PER_M_Y 10000 //10000 #define STEPS_PER_M_Z 300000 //200000 /// [blog.arcol.hu] may help with this one #define STEPS_PER_M_E 150000 //100000 /* Values depending on the capabilities of your stepper motors and other mechanics. All numbers are integers, no decimals allowed. Units are mm/min */ /// used for G0 rapid moves and as a cap for all other feedrates #define MAXIMUM_FEEDRATE_X 2000 #define MAXIMUM_FEEDRATE_Y 2000 #define MAXIMUM_FEEDRATE_Z 200 #define MAXIMUM_FEEDRATE_E 2000 /// used when searching endstops and as default feedrate #define SEARCH_FEEDRATE_X 50 #define SEARCH_FEEDRATE_Y 50 #define SEARCH_FEEDRATE_Z 50 // no SEARCH_FEEDRATE_E, as E can't be searched /** \def SLOW_HOMING wether to search the home point slowly With some endstop configurations, like when probing for the surface of a PCB, you can't deal with overrunning the endstop. In such a case, uncomment this definition. */ // #define SLOW_HOMING /// this is how many steps to suck back the filament by when we stop. set to zero to disable #define E_STARTSTOP_STEPS 289
Re: Problème d'impression yoda June 18, 2013 12:13PM |
Re: Problème d'impression yoda June 18, 2013 12:26PM |
Re: Problème d'impression yoda June 18, 2013 12:43PM |
Re: Problème d'impression yoda June 18, 2013 01:14PM |
Re: Problème d'impression yoda June 18, 2013 03:46PM |
Re: Problème d'impression yoda June 18, 2013 05:26PM |
Re: Problème d'impression yoda June 19, 2013 02:16AM |
