Problème première utilisation - Thermistance non reconnue March 03, 2015 05:29PM |
Re: Problème première utilisation - Thermistance non reconnue March 03, 2015 09:14PM |
Re: Problème première utilisation - Thermistance non reconnue March 04, 2015 04:57AM |
//--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table // //// Temperature sensor settings: // -2 is thermocouple with MAX6675 (only for sensor 0) // -1 is thermocouple with AD595 // 0 is not used // 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) // 3 is mendel-parts thermistor (4.7k pullup) // 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! // 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan) (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) // 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) // 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) // 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup) // 10 is 100k RS thermistor 198-961 (4.7k pullup) // // 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k // (but gives greater accuracy and more stable PID) // 51 is 100k thermistor - EPCOS (1k pullup) // 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup) // 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan) (1k pullup) #define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 1
#define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 1 #define TEMP_SENSOR_2 1 #define TEMP_SENSOR_BED 1
Re: Problème première utilisation - Thermistance non reconnue March 04, 2015 05:22AM |
Re: Problème première utilisation - Thermistance non reconnue March 04, 2015 07:28AM |
Re: Problème première utilisation - Thermistance non reconnue March 04, 2015 11:06AM |
Re: Problème première utilisation - Thermistance non reconnue March 04, 2015 12:36PM |
Sur un ramps, la thermistance du hot end ce règle sur "temp sensor 1" il est donc normal que vous n'ayez pas de réaction, vous avez confondu avec temp sensor 0.
Si vous avez une jhead, il vous faut le choix 5 (semitec) si vous avez une hexagon ou celle que l'on vends au détails choix 1 (epcos 100k).
#define TEMP_SENSOR_0 0 #define TEMP_SENSOR_1 5 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 1
Arduino : 1.6.0 (Windows 8), Carte : "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)" ultralcd.cpp: In function 'void lcd_tune_menu()': ultralcd.cpp:317:65: error: 'HEATER_0_MAXTEMP' was not declared in this scope MENU_ITEM_EDIT(int3, MSG_NOZZLE, &target_temperature[0], 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp:107:36: note: in definition of macro 'MENU_ITEM' menu_action_ ## type ( args ); \ ^ ultralcd.cpp:317:5: note: in expansion of macro 'MENU_ITEM_EDIT' MENU_ITEM_EDIT(int3, MSG_NOZZLE, &target_temperature[0], 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp: In function 'void lcd_control_temperature_menu()': ultralcd.cpp:516:65: error: 'HEATER_0_MAXTEMP' was not declared in this scope MENU_ITEM_EDIT(int3, MSG_NOZZLE, &target_temperature[0], 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp:107:36: note: in definition of macro 'MENU_ITEM' menu_action_ ## type ( args ); \ ^ ultralcd.cpp:516:5: note: in expansion of macro 'MENU_ITEM_EDIT' MENU_ITEM_EDIT(int3, MSG_NOZZLE, &target_temperature[0], 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp:529:55: error: 'HEATER_0_MAXTEMP' was not declared in this scope MENU_ITEM_EDIT(float3, MSG_MIN, &autotemp_min, 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp:107:36: note: in definition of macro 'MENU_ITEM' menu_action_ ## type ( args ); \ ^ ultralcd.cpp:529:5: note: in expansion of macro 'MENU_ITEM_EDIT' MENU_ITEM_EDIT(float3, MSG_MIN, &autotemp_min, 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp:530:55: error: 'HEATER_0_MAXTEMP' was not declared in this scope MENU_ITEM_EDIT(float3, MSG_MAX, &autotemp_max, 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp:107:36: note: in definition of macro 'MENU_ITEM' menu_action_ ## type ( args ); \ ^ ultralcd.cpp:530:5: note: in expansion of macro 'MENU_ITEM_EDIT' MENU_ITEM_EDIT(float3, MSG_MAX, &autotemp_max, 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp: In function 'void lcd_control_temperature_preheat_pla_settings_menu()': ultralcd.cpp:552:64: error: 'HEATER_0_MAXTEMP' was not declared in this scope MENU_ITEM_EDIT(int3, MSG_NOZZLE, &plaPreheatHotendTemp, 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp:107:36: note: in definition of macro 'MENU_ITEM' menu_action_ ## type ( args ); \ ^ ultralcd.cpp:552:5: note: in expansion of macro 'MENU_ITEM_EDIT' MENU_ITEM_EDIT(int3, MSG_NOZZLE, &plaPreheatHotendTemp, 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp: In function 'void lcd_control_temperature_preheat_abs_settings_menu()': ultralcd.cpp:567:64: error: 'HEATER_0_MAXTEMP' was not declared in this scope MENU_ITEM_EDIT(int3, MSG_NOZZLE, &absPreheatHotendTemp, 0, HEATER_0_MAXTEMP - 15); ^ ultralcd.cpp:107:36: note: in definition of macro 'MENU_ITEM' menu_action_ ## type ( args ); \ ^ ultralcd.cpp:567:5: note: in expansion of macro 'MENU_ITEM_EDIT' MENU_ITEM_EDIT(int3, MSG_NOZZLE, &absPreheatHotendTemp, 0, HEATER_0_MAXTEMP - 15); ^ Erreur lors de la compilation. Ce rapport contiendrait plus d'informations si l'option "Montrer les informations de sortie pendant la compilation" était activée dans Fichier > Préférences.
#define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 5 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 1puis
#define TEMP_SENSOR_0 5 #define TEMP_SENSOR_1 5 #define TEMP_SENSOR_2 5 #define TEMP_SENSOR_BED 1
Re: Problème première utilisation - Thermistance non reconnue March 04, 2015 12:47PM |
Re: Problème première utilisation - Thermistance non reconnue March 04, 2015 01:14PM |
// This determines the communication speed of the printer //#define BAUDRATE 250000 #define BAUDRATE 250000et modifier également la vitesse à 250000 sur repetier. (ça ne fonctionne pas avec 115200, même si c'est sur le firmware et repetier)
#define TEMP_SENSOR_0 5 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 1et
