Re: ORD BOT HADRON September 24, 2013 05:25AM |
Re: ORD BOT HADRON September 25, 2013 04:06AM |
Re: ORD BOT HADRON September 25, 2013 05:40AM |
Re: ORD BOT HADRON September 25, 2013 01:07PM |
Re: ORD BOT HADRON September 25, 2013 06:11PM |
Re: ORD BOT HADRON September 26, 2013 02:50AM |
Re: ORD BOT HADRON September 26, 2013 03:50AM |
Kourou
le gars qui a fait la pièce aurait du mettre des ponts
Re: ORD BOT HADRON September 26, 2013 04:52AM |
kourou
alors télécharger la version + les dépendances seven ,mais pour ça "" Maintenant, ouvrez cmd,
exécutez les commandes suivantes:
cd C: \ pyglet-1.1.4
python setup.py install , j'ai toujours erreur
chemin d'accès spécifié introuvable, je comprends bien que je ne lui indique pas le bon chemin! donc
Re: ORD BOT HADRON September 26, 2013 05:08AM |
Re: ORD BOT HADRON September 26, 2013 02:19PM |
Re: ORD BOT HADRON September 26, 2013 03:23PM |
Re: ORD BOT HADRON September 26, 2013 03:24PM |
Re: ORD BOT HADRON September 27, 2013 12:27AM |
Re: ORD BOT HADRON September 27, 2013 03:34AM |
Re: ORD BOT HADRON October 01, 2013 10:58AM |
Re: ORD BOT HADRON October 01, 2013 11:09AM |
Re: ORD BOT HADRON October 01, 2013 11:30AM |
non c bon|
Re: ORD BOT HADRON October 01, 2013 11:41AM |
Re: ORD BOT HADRON October 01, 2013 11:54AM |
Re: ORD BOT HADRON October 02, 2013 01:27PM |
Re: ORD BOT HADRON October 02, 2013 01:43PM |
Re: ORD BOT HADRON October 03, 2013 01:38AM |
Re: ORD BOT HADRON October 08, 2013 12:23PM |
Re: ORD BOT HADRON October 08, 2013 01:52PM |
Re: ORD BOT HADRON October 08, 2013 01:58PM |
kourou
par contre j'ai du mettre pour du PLA 185° HEAT ET 110° BED !! et j'ai la LED du lit que ne s'allume plus mais le lit chauffe ,10 mn pour 100°
Re: ORD BOT HADRON October 08, 2013 02:42PM |
Re: ORD BOT HADRON October 09, 2013 05:07AM |
Re: ORD BOT HADRON October 09, 2013 05:38AM |
Re: ORD BOT HADRON October 09, 2013 07:48AM |
237V entrée de l'alim livrée avec la ordbot ,12.05v en sortie vers la ramps 1.4 ,le ventilo fonctionne ,les câbles a leur place ,usb changé ,alors a l'instant je viens de retirer la ramps de la funduino et reset et le voyant vert est allumer , je test et reviens|
Re: ORD BOT HADRON October 09, 2013 10:41AM |
