Des conseils d'optimisation Slic3r
August 13, 2013 10:51PM
Hello tout monde,
Je début dans la réalisation des pièces et pour le moment j'en suis juste à réalisé les pièces de calibrage.
Elles ne sont pas terrible.
J'ai une prusa v2 en 0.35
Quelqu'un aurait il des conseils pour optimiser Slic3r?
# generated by Slic3r 0.9.11-dev on Wed Aug 14 04:09:03 2013
avoid_crossing_perimeters = 1
bed_size = 190,160
bed_temperature = 70
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 60
brim_width = 0
complete_objects = 0
cooling =
default_acceleration = 0
disable_fan_first_layers = 1
duplicate = 1
duplicate_distance = 6
duplicate_grid = 1,1
end_gcode = M104 S0 ; turn off temperature\nG28 X0  ; home X axis\nM84     ; disable motors
external_perimeter_speed = 70%
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 0
fan_always_on = 0
fan_below_layer_time = 60
filament_diameter = 2.89
fill_angle = 45
fill_density = 0.4
fill_pattern = line
first_layer_acceleration = 0
first_layer_bed_temperature = 65
first_layer_extrusion_width = 80%
first_layer_height = 0.35
first_layer_speed = 30%
first_layer_temperature = 190
g0 = 0
gap_fill_speed = 20
gcode_arcs = 0
gcode_comments = 1
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_speed = 60
layer_gcode =
layer_height = 0.4
max_fan_speed = 100
min_fan_speed = 35
min_print_speed = 10
min_skirt_length = 0
notes =
nozzle_diameter = 0.5
only_retract_when_crossing_perimeters = 1
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 30
perimeters = 3
post_process =
print_center = 95,80
raft_layers = 0
randomize_start = 0
resolution = 0
retract_before_travel = 2
retract_layer_change = 1
retract_length = 1
retract_length_toolchange = 10
retract_lift = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 45
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 1
slowdown_below_layer_time = 30
small_perimeter_speed = 30
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0
solid_infill_speed = 60
spiral_vase = 0
start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle
start_perimeters_at_concave_points = 0
start_perimeters_at_non_overhang = 0
support_material = 0
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_extruder = 1
support_material_interface_layers = 3
support_material_interface_spacing = 0
support_material_pattern = honeycomb
support_material_spacing = 2.5
support_material_speed = 60
support_material_threshold = 0
temperature = 200
thin_walls = 1
threads = 1
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 50
top_solid_layers = 3
travel_speed = 130
use_relative_e_distances = 0
vibration_limit = 0
wipe = 0
z_offset = 0
Merci pour vos réponses smiling smiley
zas
Re: Des conseils d'optimisation Slic3r
August 14, 2013 01:09AM
Yopla zas...
Alors a première vus, il y'a une petit soucis au niveau du "layer_height", il devrais être au maximum de 80% la taille du nozzel, donc pour une buze de 0.35, je prendrais plutôt 0.2, mais surement pas 0.4... pareil pour le "first_layer_height" qui devrais idéalement être le même que "layer_height",(si tu dois le modifier c'est que la machine n'est pas bien calibrée notamment le Z zéro).
Deuxième chose, avec une prusa même I2, si tu na pas de Frame Stabilizer oublie les grande vitesses ou les Jerk* trop important, donc dans un premier temps je descendrais les valeurs de "infill_speed","solid_infill_speed" et "top_solid_infill_speed" a 40 et remonter progressivement jusqu’à trouver la valeur max pour ta machine. Pareil pour le "travel_speed", en commençant a 60.
* Le Jerk ce règle dans le Firmware.
"Ils ne savaient pas que c'était impossible alors ils l'ont fait!" Mark Twain
[DOC][CONFIG] Hauteur de couche (Layer height)
Lautr3k - A 3D printer without belts
iTopie - A Swissmade RepRap
August 14, 2013 11:23AM
Merci pour votre réponse.
En ce qui concerne l'Axe Z j'utilise l'outil présent ici.
Tige filté M8; Moteur nema 17 200; drivers A4988 qui sont à 1/16 je crois.
(200 * 16) / 1.25 = 2560
Pour le Jerk, je n'y est pas encore touché je ne sais pas comment configurer, ni se que cela implique vraiment dans la conception. auriez vous une donc à me soumettre ?
J'ai remarqué toutefois avec les nouveaux paramètres entré dans slic3r que l'extruder ne débit pas assez de filament de plastique. Voici ce que j'ai dans configuration.h
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,2560,772} // Test
Je ne suis pas sur du 772. Qd je faisais les mesures comme précisé dans le wiki. Je trouvais 625.33. Mais avec cette valeur je n'avais pas du tout de plastique qui sortait lors de la réalisation.
Les valeurs presente par defaut dans le firmware marlin etait de 760*1.1. Je ne pourrais pas explique cette valeur mais la pièce de calibration wall se réalise moyennement bien. Mais je plastique sort mieux.
Si quelqu'un à une idée.
Edited 1 time(s). Last edit at 08/14/2013 11:39AM by zasquash.
August 14, 2013 11:54AM
Yopla zasquash
zasquash
En ce qui concerne l'Axe Z j'utilise l'outil présent ici:
Ca c'est bon smiling smiley
zasquash
Pour le moment c'est pas important, on oublie.
zasquash
Pourquoi avoir changer cette valeur si elle étais bonne? Le meilleur moyen de configurer (affiner) le E_step c'est par la mesure.
Regarde par ici pour une marche a suivre.
zasquash
Pas du tout de plastique? la c'est bizarre, la différence n'est pas énorme, un peu moins de plastique ok, pas du tout...problème.
Quelques photos ne seront pas de trop tongue sticking out smiley
Peace.
August 14, 2013 01:08PM
Merci pour votre temps.
    zasquash
Oui je n'avais pas de plastique car l'imprimante allait beaucoup trop vite par rapport au valeur écrite dans le firmware.
(je suis entrain de me demander si le vendeur ne m'a pas vendu une 0.5 comme extrudeur au lieu du 0.35.)confused smiley
Je vous fais les photos ce soir
August 14, 2013 06:15PM
Hello voilà les photos.
J'ai de nouveau suivis le tutoriel de paramettrage de l'axe E. Je trouve la meme valeur qu'au départ à savoir 700.
Le résultat, sur la photo, n'est pas au rendez vous. voici mon slic3r:
# generated by Slic3r 0.9.11-dev on Wed Aug 14 23:31:29 2013
bed_size = 190,160
bridge_speed = 50
brim_width = 0
cooling =
duplicate = 1
end_gcode = G1 X12.0 F4000  ; home (almost) x - stops extruder crashing into frame if at very top of Z height\nG1 Y160 F4000   ; move the print to the front.\nM104 S0             ; make sure the extuder is turned off.\nM140 S0             ; make sure the bed is turned off.\nM84                    ; shut down motors.
extrusion_axis = E
extrusion_width = 0
fan_always_on = 0
filament_diameter = 2.95
fill_angle = 45
fill_density = 0.5
first_layer_height = 0.2
first_layer_speed = 20%
first_layer_temperature = 215
g0 = 0
gap_fill_speed = 20
gcode_arcs = 0
gcode_comments = 1
infill_extruder = 1
infill_first = 0
infill_speed = 60
layer_gcode =
layer_height = 0.2
max_fan_speed = 100
min_fan_speed = 35
notes =
nozzle_diameter = 0.35
output_filename_format = /home/alex/Modèle/gcode/[input_filename_base].gcode
overhangs = 1
perimeters = 3
post_process =
raft_layers = 0
randomize_start = 0
resolution = 0
retract_length = 1
retract_lift = 0
retract_speed = 30
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 1
solid_infill_below_area = 3
solid_infill_speed = 60%
spiral_vase = 0
start_gcode = G21                  ; set units to millimeters\nG28                  ; home all axes\nG1 Z5 F5000    ; lift nozzle\nM109 S185      ; wait for temperature to be reached\nM190 S65        ; wait for bed temperature to be reached\nG28                 ; home all axes\nG90                 ; use absolute coordinates\nG92 E0
temperature = 185
thin_walls = 1
threads = 1
toolchange_gcode =
top_solid_infill_speed = 40%
travel_speed = 60
vibration_limit = 0
wipe = 0
z_offset = 0
Lorsque je mesure la taille du filament de sortie une fois refroidie avec un pied a coulisse non numérique. J'ai l'impression que sa fait 1/2 millimètre.
Ce qui expliquerai bien des choses smiling smiley
Edited 1 time(s). Last edit at 08/14/2013 06:18PM by zasquash.
open | download - IMG_20130814_235403.jpg (402.9 KB)
August 15, 2013 03:25AM
Yopla,
c'est normal, une buse de 0.35 en extrusion libre (dans le vide) sort un fil d'environs 0.40/0.45.
Sur la photo le fil a l'air pas mal, et ont voie un bout de skirt qui a l'air pas mal aussi.
On peu avoir les photos de tes pièces de testes "pas terrible" que tu a imprimée?
Parce-que la c'est difficile de comprendre concrètement ton problème.
Peace.
August 21, 2013 01:17PM
bon voilà les fichiers.
Je ne sais pas si c'est super clair.
open | download - IMG_20130821_184732.jpg (201.1 KB)
open | download - IMG_20130821_184747.jpg (191.9 KB)
August 22, 2013 04:20PM
c'est assez étrange, tu as reglé correctement le débit du fil dans le firmware ?
sinon avec ma prusa 2,; je tourne sans pb à 50mm et 60 pour le solid infill
August 22, 2013 04:56PM
Est ce que tu pourrais m'envoyer ton Slic3r pour que je vois. Je puisse traiter le problème de comparaison.
Alex
August 23, 2013 05:58PM
Les 3 premières couche sont bonne mais apres sa commence à partir en cacahouète...
une idée ?
open | download - IMG_20130823_231636.jpg (229.1 KB)
August 24, 2013 03:23AM
Beaucoup trop chaud, Extruder mal calibré ?
August 24, 2013 04:19AM
Bonjour,
D'après ta température de fonctionnement 200°C tu utilises du PLA !?
il se pourrait que ce soit un problème de friction du PLA dans le tube du hot end : si le haut du hot end n'est pas refroidi convenablement, le filament devient chaud non seulement à l'extrémité du hot end mais sur toute la longueur du hot end et dans ce cas il se déforme et coulisse mal voire se bloque.
En général ce phénomène se traduit par des premières couches impécables et ensuite des couches où il manque de la matière (sortie de filament irrégulier ou blocage total).
Ce problème est particulier au PLA, il est plus rare avec de l'ABS.
Quelle hot end as-tu ?
As-tu un ventilateur de refroidissement bien orienté sur le haut du hot end ?
Cordialement
PRP
August 24, 2013 05:45AM
nan je n'ai pas de ventilateur sur le hotend je pensais le fabriquer avec l'imprimante.
je pense que j'ai un 0.5 mais pas sur.
Je vais faire des essaie avec en calibrant slic3r 0.35
August 24, 2013 06:13AM
je voudrais aussi en fabriquer un support fan 40 X 40 mm de Thingiverse mais je ne sais lequel choisir dans le tas !
kourou
