Montage d'une hot-end J-Head December 11, 2013 02:15PM |
Re: Montage d'une hot-end J-Head December 11, 2013 02:32PM |
Re: Montage d'une hot-end J-Head December 11, 2013 04:47PM |
Re: Montage d'une hot-end J-Head December 11, 2013 10:13PM |
Re: Montage d'une hot-end J-Head December 12, 2013 01:26AM |
Re: Montage d'une hot-end J-Head December 12, 2013 02:42AM |
Re: Montage d'une hot-end J-Head December 12, 2013 04:30PM |
Re: Montage d'une hot-end J-Head December 13, 2013 03:03AM |
The 3mm liner has an ID of 0.128" and the OD is 0.250". The top end has an internal taper to help guide the filament.
The 1.75mm liner has an ID of 2mm and an OD of 0.250". The top end is designed to retain a short piece of tubing that guides the filament through the hollow set-screw. This guide tubing is also included.
Re: Montage d'une hot-end J-Head December 13, 2013 12:11PM |
Re: Montage d'une hot-end J-Head December 14, 2013 04:53AM |
Re: Montage d'une hot-end J-Head December 15, 2013 02:27AM |
Re: Montage d'une hot-end J-Head December 15, 2013 05:09AM |
Re: Montage d'une hot-end J-Head December 15, 2013 11:50AM |
