Pb Arduino ramps1.4 et ecran lcd 12864 April 01, 2014 03:59PM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 01, 2014 04:14PM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 01, 2014 05:19PM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 01, 2014 05:26PM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 01, 2014 05:54PM |
//LCD and SD support #define ULTRA_LCD //general lcd support, also 16x2 #define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) #define SDSUPPORT // Enable SD Card Support in Hardware Console //#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) #define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder #define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking #define ULTIMAKERCONTROLLER //as available from the ultimaker online store. CHEZ MOI C EST ACTIVE MAIS JE NE PENSE PAS QUE CA SOIT UTILE AU FINAL #define ULTIPANEL //the ultipanel as on thingiverse CHEZ MOI C EST ACTIVE MAIS JE NE PENSE PAS QUE CA SOIT UTILE AU FINAL // The MaKr3d Makr-Panel with graphic controller and SD support // [reprap.org] //#define MAKRPANEL // The RepRapDiscount Smart Controller (white PC // [reprap.org] //#define REPRAP_DISCOUNT_SMART_CONTROLLER // The GADGETS3D G3D LCD/SD Controller (blue PC // [reprap.org] //#define G3D_PANEL // The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC // [reprap.org] // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// Languages
// 1 English
// 2 Polish
// 3 French
// 4 German
// 5 Spanish
// 6 Russian
// 7 Italian
// 8 Portuguese
// 9 Finnish
#ifndef LANGUAGE_CHOICE
#define LANGUAGE_CHOICE 3 // Pick your language from the list above
#endif
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 01, 2014 06:07PM |
One-T
un conseil ne touche pas au bouton poussoir qui est sur la platine, il plante l'arduino et tu est obligé de rallumer l'imprimante . aucune idée de pourquoi cela fait ca mais je ne suis pas le seul
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 01, 2014 07:10PM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 02, 2014 12:57AM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 02, 2014 05:33AM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 02, 2014 11:08AM |
#if defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL)
#define KILL_PIN 41
#else
#define KILL_PIN -1
#endif
// [reprap.org]
#if defined (REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER)
#define DOGLCD
#define U8GLIB_ST7920
#endif
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 02, 2014 06:22PM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 10, 2014 01:11AM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 10, 2014 05:14AM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 10, 2014 11:33AM |
Pb Arduino ramps1.4 et ecran lcd 12864 April 14, 2014 09:38AM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 14, 2014 11:48AM |
Re: Pb Arduino ramps1.4 et ecran lcd 12864 April 14, 2014 12:38PM |
