Gcode pour pin aux June 09, 2014 01:59AM |
Re: Gcode pour pin aux June 09, 2014 12:51PM |
Re: Gcode pour pin aux June 09, 2014 02:07PM |
Re: Gcode pour pin aux June 09, 2014 02:09PM |
Re: Gcode pour pin aux June 09, 2014 02:47PM |
Re: Gcode pour pin aux June 09, 2014 03:35PM |
; generated by Slic3r 1.0.1 on 2014-06-09 at 21:18:39 ; layer_height = 0.3 ; perimeters = 3 ; top_solid_layers = 3 ; bottom_solid_layers = 3 ; fill_density = 0.3 ; perimeter_speed = 30 ; infill_speed = 60 ; travel_speed = 60 ; nozzle_diameter = 0.4 ; filament_diameter = 1.75 ; extrusion_multiplier = 1 ; perimeters extrusion width = 0.40mm ; infill extrusion width = 0.42mm ; solid infill extrusion width = 0.42mm ; top infill extrusion width = 0.42mm ; support material extrusion width = 0.40mm ; first layer extrusion width = 0.78mm G21 ; set units to millimeters M107 M190 S50 ; wait for bed temperature to be reached M104 S220 ; set temperature G28 ; home all axes M42 S255 P44 ;Sortie D44 à 1
Re: Gcode pour pin aux June 09, 2014 03:55PM |
Re: Gcode pour pin aux June 09, 2014 03:56PM |
Re: Gcode pour pin aux June 10, 2014 06:28AM |
Re: Gcode pour pin aux June 10, 2014 07:25AM |
case 42: //M42 -Change pin status via gcode
if (code_seen('S'))
int pin_status = code_value();
int pin_number = LED_PIN;
if (code_seen('P') && pin_status >= 0 && pin_status <= 255)
pin_number = code_value();
for(int8_t i = 0; i < (int8_t)(sizeof(sensitive_pins)/sizeof(int)); i++)
if (sensitive_pins == pin_number)
pin_number = -1;
break;
#if defined(FAN_PIN) && FAN_PIN > -1
if (pin_number == FAN_PIN)
fanSpeed = pin_status;
#endif
if (pin_number > -1)
pinMode(pin_number, OUTPUT);
digitalWrite(pin_number, pin_status);
analogWrite(pin_number, pin_status);
break;
Strofe
ça fonctionne mais c'est étrange les sorties sont gérées en PWM.. S1 la led est faiblement allumée et à 255 elle est plein pot...
Re: Gcode pour pin aux June 10, 2014 04:25PM |
