Re: Maximus : Imprimante format XL May 25, 2015 03:59AM |
Re: Maximus : Imprimante format XL May 25, 2015 06:53AM |
Re: Maximus : Imprimante format XL May 25, 2015 08:51AM |
/*********************************************************************\ * R/C SERVO support * Sponsored by TrinityLabs, Reworked by codexmas **********************************************************************/ // Number of servos // // If you select a configuration below, this will receive a default value and does not need to be set manually // set it manually if you have more servos than extruders and wish to manually control some // leaving it undefined or defining as 0 will disable the servo subsystem // If unsure, leave commented / disabled // #define NUM_SERVOS 1 // Servo index starts with 0 for M280 command // Servo Endstops // // This allows for servo actuated endstops, primary usage is for the Z Axis to eliminate calibration or bed height changes. // Use M206 command to correct for switch height offset to actual nozzle height. Store that setting with M500. // #define SERVO_ENDSTOPS {-1, -1, 0} // Servo index for X, Y, Z. Disable with -1 #define SERVO_ENDSTOP_ANGLES {0,0, 0,0, 90,5} // X,Y,Z Axis Extend and Retract angles #include "Configuration_adv.h" #include "thermistortables.h" #endif //__CONFIGURATION_H
Re: Maximus : Imprimante format XL May 25, 2015 11:24AM |
Re: Maximus : Imprimante format XL May 25, 2015 11:40AM |
Re: Maximus : Imprimante format XL May 25, 2015 01:26PM |
Re: Maximus : Imprimante format XL June 23, 2015 01:03AM |
Re: Maximus : Imprimante format XL June 23, 2015 01:41AM |
luis0301
bonjour je voudrais savoir ou l acheter et a conbien ,quant je vais sur le site celui ci et en maintenance
Re: Maximus : Imprimante format XL June 24, 2015 12:32AM |
luis0301
