Ecran LCD 12864 Question alim et sens bouton ? October 01, 2014 01:35PM |
Re: Ecran LCD 12864 Question alim et sens bouton ? October 01, 2014 02:37PM |
Re: Ecran LCD 12864 Question alim et sens bouton ? October 01, 2014 03:56PM |
Re: Ecran LCD 12864 Question alim et sens bouton ? October 01, 2014 04:58PM |
Re: Ecran LCD 12864 Question alim et sens bouton ? October 01, 2014 06:06PM |
Re: Ecran LCD 12864 Question alim et sens bouton ? October 03, 2014 05:17PM |
// Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z true #define DISABLE_E false // For all extruders #define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled #define INVERT_X_DIR false // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
// Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z true #define DISABLE_E false // For all extruders #define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled #define INVERT_X_DIR false // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1 #define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
Re: Ecran LCD 12864 Question alim et sens bouton ? October 04, 2014 02:51AM |
Re: Ecran LCD 12864 Question alim et sens bouton ? October 04, 2014 10:42AM |
christlep
Salut
Ce jumper ne sert pas pour l'ecran, mais pour les servos il me semble.
Moi avec la meme config que toi, l'ecran s'allume (inscription et retroeclairage) avec l'alim et juste retroeclairage avec usb, chose que j'aimerai bien virer car c'est chi.... penible de devoir debrancher l'usb dés qu'on ne se sert plus de l'imprimante.
Donc je suis ce post avec interet.
A+
Chris
Re: Ecran LCD 12864 Question alim et sens bouton ? February 22, 2015 03:46PM |
didierh
Hello
dans le fichier configuration.h il y a un define
#define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder
peut-être augmenter la valeur (ici c'est celui de mon fichier)
pour l'alim ça dépend de la carte - sur la mienne (megatronics) de mémoire il y a un jumper qui détermine si le 5V vient de l'USB ou de la carte.
Par défaut apparemment il est mis sur l'alim de la carte mais une carte n'est pas l'autre.
A+ Didier
Re: Ecran LCD 12864 Question alim et sens bouton ? February 22, 2015 06:55PM |
Re: Ecran LCD 12864 Question alim et sens bouton ? October 04, 2016 07:24AM |
Re: Ecran LCD 12864 Question alim et sens bouton ? October 04, 2016 10:34AM |
Admin Registered: 13 years ago Posts: 2,569 |
Re: Ecran LCD 12864 Question alim et sens bouton ? October 10, 2016 01:08PM |
