Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin November 17, 2015 02:42AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin November 17, 2015 05:46PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin November 18, 2015 01:45AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin November 18, 2015 03:32PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin November 18, 2015 04:22PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin November 18, 2015 05:10PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin November 27, 2015 03:15PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin November 28, 2015 09:18AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin March 17, 2016 09:53AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin March 17, 2016 10:16AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin March 17, 2016 10:26AM |
l'axe des Z lors de la coupe est inversé mais comment le paramétrer?c'est ton logiciel de fao(solidcam) qui va generer le gcode avec les z en négatifs !
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin March 18, 2016 05:23AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin March 18, 2016 07:28AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin March 29, 2016 05:51AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin March 30, 2016 01:32PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin April 02, 2016 05:36AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin April 02, 2016 09:44AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin July 20, 2016 05:08PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin August 01, 2016 03:49AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin August 01, 2016 04:14AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin August 24, 2016 05:33PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin August 24, 2016 06:03PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin August 25, 2016 03:47PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin December 23, 2016 10:57AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin December 23, 2016 05:00PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin December 23, 2016 05:25PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin December 23, 2016 05:56PM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin December 24, 2016 08:06AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin December 25, 2016 05:34AM |
Re: Pilotage CNC via RAMPS 1.4 et firmware Marlin December 25, 2016 03:16PM |
Honnêtement, je ne saurais pas te dire. Par contre, on peut faire varier la largeur en tournant la lentille qui permet la mise au point et ça dépend aussi de la hauteur... D'après ce que j'ai vu le rayon peut varier de 1 mm de diamètre à beaucoup moins pour une puissance supérieure . Plus le rayon est fin (meilleure focalisation) plus la découpe est efficace.Quote
blonblon
ThierryM le faisceau de ta diode fait un sillon de découpe de quelle largeur, et est ce que c'est réglable..
J'ai fait des essais à la "louche". La plaque martyre est toujours attaquée quand on traverse mais c'est vraiment superficiel (c'est de la gravure) et puis vu la puissance de mon laser ça ne fait quand même pas trop de mal.Quote
blonblon
Comment a tu défini la hauteur a laquelle doit etre la diode pour ne pas attaquer la plaque martyre sous la piéce a travailler..
Je n'utilise pas la variation pulse PWM (ça serait possible sur ma carte via l'entrée TTL mais je ne suis pas allé aussi loin). Donc soit c'est allumé (à 100%) soit c'est éteint. Par contre, la variation de puissance doit avoir plus d'utilité pour un laser plus puissant.Quote
blonblon
Est ce que la diode doit etre utilisée en allumage continu, ou en allumage pulsé..
Du papier de 80g, en 1 passe avec un déplacement à 100 mm/min.Quote
blonblon
Qu'a tu découpé comme matières au laser..
