Filament Runout Sensor March 26, 2015 07:49AM |
//============================= Filament Runout Sensor ======================
//#define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament
// In RAMPS uses servo pin 2. Can be changed in pins file. For other boards pin definition should be made.
// It is assumed that when logic high = filament available
// when logic low = filament ran out
//const bool FIL_RUNOUT_INVERTING = true; // Should be uncommented and true or false should assigned
//#define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
Re: Filament Runout Sensor April 02, 2015 12:53PM |
Re: Filament Runout Sensor April 02, 2015 03:13PM |
Re: Filament Runout Sensor April 03, 2015 03:07AM |
Re: Filament Runout Sensor April 03, 2015 05:36AM |
Re: Filament Runout Sensor April 06, 2015 03:46AM |
salutQuote
filament-abs
Un tel capteur est déjà intégré dans les imprimantes Stream de chez Volumic3D. C'est assez génial, il faut le reconnaitre; non seulement on peut aller au bout des bobines et éviter ainsi le gaspillage mais ça permet également d'imprimer facilement en plusieurs couleurs même avec un seul extrudeur.
Re: Filament Runout Sensor April 07, 2015 04:44PM |
Re: Filament Runout Sensor April 08, 2015 03:03AM |
Re: Filament Runout Sensor April 08, 2015 10:55AM |
Re: Filament Runout Sensor April 04, 2017 07:45AM |
