Probleme de reglage extrudeur April 16, 2015 03:25PM |
Re: Probleme de reglage extrudeur April 16, 2015 04:02PM |
Re: Probleme de reglage extrudeur April 16, 2015 05:09PM |
Re: Probleme de reglage extrudeur April 17, 2015 08:28AM |
Re: Probleme de reglage extrudeur April 17, 2015 08:32AM |
Re: Probleme de reglage extrudeur April 17, 2015 08:40AM |
Re: Probleme de reglage extrudeur April 17, 2015 09:16AM |
Re: Probleme de reglage extrudeur April 17, 2015 09:28AM |
Re: Probleme de reglage extrudeur April 17, 2015 10:39AM |
Re: Probleme de reglage extrudeur April 22, 2015 03:44PM |
Re: Probleme de reglage extrudeur April 22, 2015 03:53PM |
Re: Probleme de reglage extrudeur April 22, 2015 04:00PM |
Re: Probleme de reglage extrudeur April 22, 2015 04:12PM |
Re: Probleme de reglage extrudeur April 22, 2015 06:18PM |
Re: Probleme de reglage extrudeur April 25, 2015 05:39AM |
Re: Probleme de reglage extrudeur April 25, 2015 09:56AM |
//// Temperature sensor settings: // -2 is thermocouple with MAX6675 (only for sensor 0) // -1 is thermocouple with AD595 // 0 is not used // 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) // 3 is Mendel-parts thermistor (4.7k pullup) // 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! // 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) // 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) // 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup) // 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) // 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup) // 10 is 100k RS thermistor 198-961 (4.7k pullup) // 11 is 100k beta 3950 1% thermistor (4.7k pullup) // 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed) // 13 is 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE" // 20 is the PT100 circuit found in the Ultimainboard V2.x // 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950 // // 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k // (but gives greater accuracy and more stable PID) // 51 is 100k thermistor - EPCOS (1k pullup) // 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup) // 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup) // // 1047 is Pt1000 with 4k7 pullup // 1010 is Pt1000 with 1k pullup (non standard) // 147 is Pt100 with 4k7 pullup // 110 is Pt100 with 1k pullup (non standard) // 998 and 999 are Dummy Tables. They will ALWAYS read 25°C or the temperature defined below. // Use it for Testing or Development purposes. NEVER for production machine. // #define DUMMY_THERMISTOR_998_VALUE 25 // #define DUMMY_THERMISTOR_999_VALUE 100 // :{ '0': "Not used", '4': "10k !! do not use for a hotend. Bad resolution at high temp. !!", '1': "100k / 4.7k - EPCOS", '51': "100k / 1k - EPCOS", '6': "100k / 4.7k EPCOS - Not as accurate as Table 1", '5': "100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '7': "100k / 4.7k Honeywell 135-104LAG-J01", '71': "100k / 4.7k Honeywell 135-104LAF-J01", '8': "100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT", '9': "100k / 4.7k GE Sensing AL03006-58.2K-97-G1", '10': "100k / 4.7k RS 198-961", '11': "100k / 4.7k beta 3950 1%", '12': "100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)", '13': "100k Hisens 3950 1% up to 300°C for hotend 'Simple ONE ' & hotend 'All In ONE'", '60': "100k Maker's Tool Works Kapton Bed Thermistor beta=3950", '55': "100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '2': "200k / 4.7k - ATC Semitec 204GT-2", '52': "200k / 1k - ATC Semitec 204GT-2", '-2': "Thermocouple + MAX6675 (only for sensor 0)", '-1': "Thermocouple + AD595", '3': "Mendel-parts / 4.7k", '1047': "Pt1000 / 4.7k", '1010': "Pt1000 / 1k (non standard)", '20': "PT100 (Ultimainboard V2.x)", '147': "Pt100 / 4.7k", '110': "Pt100 / 1k (non-standard)", '998': "Dummy 1", '999': "Dummy 2" } #define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 #define TEMP_SENSOR_BED 1
Re: Probleme de reglage extrudeur April 26, 2015 07:18AM |
Re: Probleme de reglage extrudeur April 26, 2015 11:41AM |
Re: Probleme de reglage extrudeur April 27, 2015 01:53PM |
Re: Probleme de reglage extrudeur April 27, 2015 09:18PM |
Re: Probleme de reglage extrudeur April 30, 2015 06:45PM |
Re: Probleme de reglage extrudeur May 08, 2015 04:51PM |
Re: Probleme de reglage extrudeur May 09, 2015 04:14AM |
Re: Probleme de reglage extrudeur May 09, 2015 04:29AM |
Re: Probleme de reglage extrudeur May 09, 2015 05:22AM |
Re: Probleme de reglage extrudeur May 09, 2015 04:39PM |
