RepRapDiscount Full Graphic Smart Controller June 16, 2015 03:42PM |
REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLERmais le fichier configuration.h marlin que j'ai il y a cette ligne
REPRAP_DISCOUNT_SMART_CONTROLLERdonc c'est pa pareil...
Re: RepRapDiscount Full Graphic Smart Controller June 16, 2015 07:49PM |
#define EEPROM_CHITCHAT //LCD and SD support //#define ULTRA_LCD //general lcd support, also 16x2 #define SDSUPPORT // Enable SD Card Support in Hardware Console //#define ULTIMAKERCONTROLLER //as available from the ultimaker online store. //#define ULTIPANEL //the ultipanel as on thingiverse // The RepRapDiscount Smart Controller // [reprap.org] #define REPRAP_DISCOUNT_SMART_CONTROLLER //automatic expansion
//LCD and SD support //#define ULTRA_LCD //general LCD support, also 16x2 //#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) //#define SDSUPPORT // Enable SD Card Support in Hardware Console //#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) //#define SD_CHECK_AND_RETRY // Use CRC checks and retries on the SD communication //#define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder //#define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking //#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store. //#define ULTIPANEL //the UltiPanel as on Thingiverse //#define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click //#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click // The MaKr3d Makr-Panel with graphic controller and SD support // [reprap.org] //#define MAKRPANEL // The RepRapDiscount Smart Controller (white PC // [reprap.org] //#define REPRAP_DISCOUNT_SMART_CONTROLLER // The GADGETS3D G3D LCD/SD Controller (blue PC // [reprap.org] //#define G3D_PANEL // The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC // [reprap.org] // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] //#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Re: RepRapDiscount Full Graphic Smart Controller June 17, 2015 02:43AM |
Re: RepRapDiscount Full Graphic Smart Controller June 17, 2015 06:11PM |
Re: RepRapDiscount Full Graphic Smart Controller June 18, 2015 03:16AM |
Re: RepRapDiscount Full Graphic Smart Controller June 18, 2015 05:23PM |
Re: RepRapDiscount Full Graphic Smart Controller June 19, 2015 03:07AM |
