[groupe buy palier igus] 8mm/ 10 mm fermeture le 15/11
Posted by quik66
Re: [groupe buy palier igus] 8mm/ 10 mm fermeture le 15/11
November 04, 2015 08:29AM
IGUS RJMP-01-08
quik66 = 20
ss650s = 12
BOBOSS = 4
joyeufetar = 11
tonybony = 16
stefc = 3
chaps92=12
Tosamdy=12
bob6199= 12
zistor= 12
Charrier=12
jcb=12
igus RJMP-01-10
BOBOSS =12
tonybony = 4
RepRapREcycle=12
Charrier=4
igus RJMP-01-12
RepRapREcycle=14
RJUM-02-08.
claude 11= 6
Edited 1 time(s). Last edit at 11/04/2015 08:33AM by quik66.
November 04, 2015 09:16AM
RJMP-01-08 x 8 pour moi winking smiley
November 04, 2015 09:41AM
IGUS RJMP-01-08
quik66 = 20
ss650s = 12
BOBOSS = 4
joyeufetar = 11
tonybony = 16
stefc = 3
chaps92=12
Tosamdy=12
bob6199= 12
zistor= 12
Charrier=12
jcb=12
lv-esad=8
igus RJMP-01-10
BOBOSS =12
tonybony = 4
RepRapREcycle=12
Charrier=4
igus RJMP-01-12
RepRapREcycle=14
RJUM-02-08.
claude 11= 6
November 04, 2015 12:31PM
IGUS RJMP-01-08
chacal1985 = 12
quik66 = 20
ss650s = 12
BOBOSS = 4
joyeufetar = 11
tonybony = 16
stefc = 3
chaps92=12
Tosamdy=12
bob6199= 12
zistor= 12
Charrier=12
jcb=12
lv-esad=8
igus RJMP-01-10
BOBOSS =12
tonybony = 4
RepRapREcycle=12
Charrier=4
igus RJMP-01-12
RepRapREcycle=14
RJUM-02-08.
claude 11= 6
November 04, 2015 12:56PM
La ref exacte est RJZM-02-08, quantité 6 au lieu de RJUM-02-08 merci de corriger.
November 04, 2015 01:10PM
IGUS RJMP-01-08
chacal1985 = 12
quik66 = 20
ss650s = 12
BOBOSS = 4
joyeufetar = 11
tonybony = 16
stefc = 3
chaps92=12
Tosamdy=12
bob6199= 12
zistor= 12
Charrier=12
jcb=12
lv-esad=8
igus RJMP-01-10
BOBOSS =12
tonybony = 4
RepRapREcycle=12
Charrier=4
igus RJMP-01-12
RepRapREcycle=14
RJzM-02-08.
claude 11= 6
November 04, 2015 01:14PM
Merci pour la rectif.
Et pour les rlts il y a des commandes?
November 04, 2015 01:52PM
j ai poster que tout a l heure
November 07, 2015 03:10AM
personne pour des roulement ?
November 07, 2015 03:24AM
Pas de besoin dans l'immédiat
November 07, 2015 03:27AM
besoin en 605zz pour itopie
desole
rv
November 07, 2015 06:22AM
Moi j'aurais besoin de 4 608ZZ et 2 605ZZ pour mon Itopie.
November 07, 2015 07:16AM
les mecs on parle de paliers , pas de roulements winking smiley
November 07, 2015 07:20AM
si one igus ma fait une proposition pour des roulement aussi smiling smiley je l ai mise un peu plus haut
November 07, 2015 07:26AM
j"ai rien dit alors mdrrr
j'ai pas tout suivis désolé
November 07, 2015 08:17AM
Bonjour,
Les roulements ça reste cher l'unité et j'ai peur qu'on atteigne pas les 100pcs.
++JM
November 07, 2015 11:37AM
oui ces ce que je pense aussi
November 07, 2015 12:11PM
Ok donc on va faire l'impasse sur les roulements!
November 09, 2015 03:31AM
Pendant que j'y pense, chez Igus ils vendent aussi des tiges lisses qui fonctionnent super bien avec les douilles igus : [www.igus.fr]
Il faudrait voir eventuellement à combien on pourrait les avoirs ( tarif normal : 8€ le m linéaire ).
Ils peuvent couper sur mesure.
November 09, 2015 04:00AM
Bonjour,
Pour les barres, c'est pas concurrentiel par rapport aux barres chinoises.
Lesquelles sont en port gratuit en plus...
En France, tout ce qui ne passe pas dans une enveloppe douille (sans mauvais jeu de mots) à la réexpédition.
++JM
jcb
November 09, 2015 04:16AM
Et puis le lien pointe sur des ronds en alu ... pas sur que cela soit suffisament rigide... et gare à la moindre torsion, l'aluminium n'ayant pas de mémoire c'est foutu...
A la limite, il vaut mieux prendre les tubles creux, c'est + rigide...
Ils ont bien de l'acier et de l'inox mais amha ce n'est pas du tout dans la même catégorie de prix (d'ailleurs prix sur demande sur ces produits...)
my 2 cts.
November 09, 2015 04:25AM
bonjour à tous,
Il vende egalement des arbres en acier.
j'ai fait une demande de prix pour réaliser une itopie mais le prix est assez élevé.
je pense que je vais rester sur du rond inox étiré dans un magasin prolian.
pour info le prix pour une itopie 4*400mm et 2*380mm 38.5€ HT
bonne journée
November 09, 2015 05:14AM
Hello,
Petit update pour moi, au final, il m'en faudrait 12 et non plus 11.
Thanks smiling smiley
November 09, 2015 06:40AM
IGUS RJMP-01-08
chacal1985 = 12
quik66 = 20
ss650s = 12
BOBOSS = 4
joyeufetar = 12
tonybony = 16
stefc = 3
chaps92=12
Tosamdy=12
bob6199= 12
zistor= 12
Charrier=12
jcb=12
lv-esad=8
igus RJMP-01-10
BOBOSS =12
tonybony = 4
RepRapREcycle=12
Charrier=4
igus RJMP-01-12
RepRapREcycle=14
RJzM-02-08.
claude 11= 6
November 09, 2015 06:52AM
J'ai reçu un sample aujourd'hui, et effectivement il y a bien du jeu, mais que d'un coté du patin.
Quand on regarde de plus pres, on voit les traces du moule d'injection, la pièce pour pouvoir être démoulée est faite dans l'axe du patin, avec un petit angle de dépouille. Donc les patins sont à proscrire sur une delta à moins d'utiliser 4 igus par axe.
Je pense que l'on peut corriger ça avec un montage adapté :
des lm8uu en schéma ça donne
Pour les igus :
Il faudra mettre le coté avec du jeu en interieur, de façon à ce que les deux parties sans jeu soient le plus éloignées possible...
Coté sans jeu
Coté avec jeu
C'est léger, environ 0.2 mm
Edited 2 time(s). Last edit at 11/09/2015 06:56AM by lv-esad.
November 09, 2015 06:59AM
merci du retour lv esad
November 09, 2015 07:16AM
Merci pour le test lv esad,
Cette histoire de jeu m'inquiète un peu quand même, t'en pense quoi au global, y a t il un réel gain par rapport aux lm8uu classiques qu'on retrouve sur nos printeuses ?
Merci smiling smiley
November 09, 2015 07:19AM
Le silence !
November 09, 2015 07:49AM
Re,
J'utilise de l'Igus depuis 2009 et des douilles depuis plus d'un an.
En fait les douilles Igus RJMP doivent être contraintes, c'est à dire serrées.
En clair, si vous les montez avec des colliers rislan, vous aurez les 0.2mm de jeu dont parle lv-essad.
Entre nous, c'est ce qu'on a +- de base sur des LM8UU donc c'est pas disqualifiant.
Il faut les monter dans des paliers à vis et serrer jusqu'à plus de jeu. Ni trop, ni trop peu.
Sinon oui, c'est super silencieux et sans entretien.
Par contre, attention aux systèmes no wobble de Z par gravité.
Les douilles Igus ont du frottement, ça ne "tombe" pas,
donc c'est pas exactement interchangeable contre des LM8UU sur toutes machines.
++JM
November 09, 2015 07:56AM
Merci à tous pour les précisions
J-Max
Est-ce que cela veut dire qu'il faut penser à un système anti backlash sur les i3 classiques ?
J'en profite pour poser une petite question, qu'Est-ce que vous pensez de ce système pour éviter le z-wobble ? [www.thingiverse.com]
Zistor !
