Questions Cnc pilotée par Ramp1.4 October 13, 2016 01:34PM |
Re: Questions Cnc pilotée par Ramp1.4 October 14, 2016 04:44AM |
Re: Questions Cnc pilotée par Ramp1.4 October 14, 2016 08:59AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Questions Cnc pilotée par Ramp1.4 October 14, 2016 01:16PM |
Re: Questions Cnc pilotée par Ramp1.4 October 14, 2016 11:39PM |
Re: Questions Cnc pilotée par Ramp1.4 October 15, 2016 03:55AM |
Re: Questions Cnc pilotée par Ramp1.4 October 15, 2016 05:40AM |
Re: Questions Cnc pilotée par Ramp1.4 October 15, 2016 11:14AM |
Re: Questions Cnc pilotée par Ramp1.4 October 15, 2016 02:31PM |
Re: Questions Cnc pilotée par Ramp1.4 October 18, 2016 07:05AM |
blonblon
DeuxVis j'ai le code source, mais je ne suis pas très a l'aise avec le code, [...]
Re: Questions Cnc pilotée par Ramp1.4 October 18, 2016 03:47PM |
Re: Questions Cnc pilotée par Ramp1.4 October 19, 2016 07:46AM |
//************************************************************************************** // Steppers redirected to fastio.h from marlin firmware // min switches remaped to AUX-3, GBRL uses pin change interrupts // simple scheme to allow future porting of next releases // command buttons currently disabled // Ramps pins config moved to ramps.h // cpu_map.h - min switches // added GRBL_RAMPS1_4.ino for arduino IDE //************************************************************************************** // Ramps 1.4 | GRBL | Test // X axis | X axis | OK working // Z axis | Y axis for dual motor Y axis | OK working // Y axis | Z axis | OK working // Ramps AUX-3 pin 3 | min X | OK working // Ramps AUX-3 pin 4 | min Y | OK working // Ramps AUX-3 pin 5 | min Z | not tested // D10 | motor ON | not tested // D9 | motor direction | not tested // D8 | coolant on | not tested //***************************************************************************************
Re: Questions Cnc pilotée par Ramp1.4 October 19, 2016 03:07PM |
Re: Questions Cnc pilotée par Ramp1.4 October 21, 2016 02:28AM |
blonblon
didierh dans un premier temps du bois peut etre de l'aluminium la rigidité de l'axe Z est bonne, il y a un manque de rigidité de l'axe X dans le sens de l'axe Y le support X Z doit etre revu, pour l'axe Y les tubes devraient etre un peu plus gros, de toute facon il faut la terminer et essayer, je possède une fraiseuse d'établi avec plateaux en fonte et suivant ce que l'on fait la rigidité est limite.
Re: Questions Cnc pilotée par Ramp1.4 October 21, 2016 04:41AM |
Re: Questions Cnc pilotée par Ramp1.4 October 21, 2016 06:24AM |
Re: Questions Cnc pilotée par Ramp1.4 November 01, 2016 01:52PM |
Re: Questions Cnc pilotée par Ramp1.4 November 06, 2016 02:44PM |
Re: Questions Cnc pilotée par Ramp1.4 November 08, 2016 06:11PM |
Re: Questions Cnc pilotée par Ramp1.4 November 09, 2016 02:34AM |
Re: Questions Cnc pilotée par Ramp1.4 November 09, 2016 04:49AM |
Re: Questions Cnc pilotée par Ramp1.4 November 09, 2016 06:01PM |
Re: Questions Cnc pilotée par Ramp1.4 December 05, 2016 10:09AM |
Re: Questions Cnc pilotée par Ramp1.4 December 06, 2016 06:22AM |
Re: Questions Cnc pilotée par Ramp1.4 December 06, 2016 08:22AM |
Re: Questions Cnc pilotée par Ramp1.4 December 06, 2016 04:22PM |
Re: Questions Cnc pilotée par Ramp1.4 December 16, 2016 10:03AM |
Re: Questions Cnc pilotée par Ramp1.4 August 18, 2017 01:29PM |
Re: Questions Cnc pilotée par Ramp1.4 August 20, 2017 08:44AM |
Re: Questions Cnc pilotée par Ramp1.4 August 25, 2017 06:28AM |
