Sous extrusion e3dv6 bowden October 30, 2016 07:38PM |
Re: Sous extrusion e3dv6 bowden October 31, 2016 02:37AM |
Re: Sous extrusion e3dv6 bowden October 31, 2016 03:21AM |
Re: Sous extrusion e3dv6 bowden October 31, 2016 09:14AM |
Le throat, a-t-il un insert en PTFE ?
♦ pas de truc qui accroche entre l'entrée et la sortie du tube ?
♦ quand tu dis 215°,c'est ta consigne, mais ta machine arrive-t-elle à les tenir ?
♦ et surtout, on ne peut s'empêcher de remarquer que le début de l'impression est parfait, ce qui me ferait regarder les composants qui chauffent trop.. Pololu de l'extrudeur, moteur de l'extrudeur..
Enfin, toutes tes impressions ressemblent au Yoda, belle base et haut crapoux ?
Re: Sous extrusion e3dv6 bowden October 31, 2016 09:42AM |
Misconfigured Retraction
Choosing slicer settings is a bit of an art and everyone has their particular preferences as to how they print. The following guidance is to help people avoid common configuration pitfalls.
A common issue is massively excessive retraction distances. In direct configurations retraction of 0.5 to 2mm is all that should be needed for ooze-free prints. We use around 0.6mm for ABS that oozes very little, and 2mm for the very floppy flexible filaments that like to ooze a great deal and need a good tug to pull back the soft filament from the melt zone. For PLA we stick with retraction settings no higher than 0.8mm.
Bowden configurations are more tricky as the amount of retraction needed is dependent on factors such as the length of tubing and the stiffness of the filament has more impact on the needed retraction. A good starting place is around the 2mm mark, which you can increase if required.
Retractions of 5mm or more are troublesome as they pull hot filament up into the cold areas of the hotend where they can freeze, adhere and jam. You should be able to print at both very high, and very low speeds with your E3D hotend, but you may need to adjust your temperatures. Very high speeds will require higher temperatures in order to melt the filament quickly enough as it passes through the hotend. Very slow prints do not require as high a temperature.
Re: Sous extrusion e3dv6 bowden October 31, 2016 09:54AM |
Re: Sous extrusion e3dv6 bowden October 31, 2016 10:19AM |
TF53
le driver moteur est à 72°, ce qui ne me parait pas excessif pour un driver moteur..
Re: Sous extrusion e3dv6 bowden October 31, 2016 10:30AM |
Re: Sous extrusion e3dv6 bowden October 31, 2016 02:41PM |
TF53
La rétractation pour le yoda était de 4mm. là, j'ai réduit à 2mm, et j'ai relancé l'impression du même yoda... Réponse dans 4 ou 5 heures!
Re: Sous extrusion e3dv6 bowden October 31, 2016 03:36PM |
Haldahir
TF53
J'ai une machine assez similaire à la tienne (Ultimaker 1 custom avec un hotend E3D). Et j'avais le même problème.
Pour la retractation il faut la baissé bien plus: (source: [wiki.e3d-online.com])
Je traduis donc pour le PLA il ne recommande pas plus de 0.8mm de retractation.
Re: Sous extrusion e3dv6 bowden October 31, 2016 04:19PM |
Re: Sous extrusion e3dv6 bowden November 01, 2016 07:31AM |
Re: Sous extrusion e3dv6 bowden November 01, 2016 08:44AM |
Re: Sous extrusion e3dv6 bowden November 01, 2016 06:18PM |
Re: Sous extrusion e3dv6 bowden November 02, 2016 12:12PM |
Re: Sous extrusion e3dv6 bowden November 11, 2016 05:54AM |
GroupB
Perso je croit que tu as trop d'amperage sur ton driver surtout si tu as un heatsink et un fan dessus, si ton heatsink sur la chip fait 76C dit toi que linterieur du driver est PAS MAL plus chaud, Le seul driver qui utilise vraiment bien les heatsink sur le dessus sont les raps128 ( la chip est modifier pour refroidir par le dessus plutot que par le dessous comme les autres). Donc mesurer le heatsink sur le dessus d'un driver qui refroidit par le dessous pour avoir la temperature du driver n'est pas vraiment ideal.
Idealement tu veux regler l'amperage des drivers a 80% de celle du moteur MAX, mais c'est pas oblige souvent tu peux avoir bien plus bas sans problem pourvu que tu ne "skip" pas, dans ton cas je crois que ton amperage est tellement fort que le driver "skip" parce que il n'est plus capable de gerer la chaleur.
Le fait que tu as printer a 50 et sa marche mieux est que plus tu va vite moin les moteur/driver chauffe puisque il ne tienne pas le max amperage aussi longtemps.
Re: Sous extrusion e3dv6 bowden November 11, 2016 06:27AM |
TF53
Ce que je ne comprends pas, c'est que si je chauffe la buse à 200° et que j'extrude le filament à la main, sur les 10 premiers cm, ça glisse tout seul, puis ça commence à devenir de plus en plus dur. Je ne comprends pas pourquoi ça me fait ça puisque la buse est neuve, d'origine, et bien ventilée...
Re: Sous extrusion e3dv6 bowden November 11, 2016 06:29AM |
Re: Sous extrusion e3dv6 bowden November 11, 2016 02:50PM |
Re: Sous extrusion e3dv6 bowden November 13, 2016 04:58AM |
Re: Sous extrusion e3dv6 bowden November 13, 2016 06:11AM |
Haldahir
Alors qu'est ce qu'ont donné tes tests?
Re: Sous extrusion e3dv6 bowden November 13, 2016 09:58AM |
Re: Sous extrusion e3dv6 bowden November 15, 2016 03:32AM |
Re: Sous extrusion e3dv6 bowden November 15, 2016 04:54AM |
Haldahir
Salut,
bon il s'avère que j'ai le même problème que toi au final. Je pensait l'avoir résolu lorsque j'ai répondu sur la rétractation mais non.
J'ai trouver des pistes dans ce post: [forums.reprap.org]
Ils parlent notamment de heat creep pour la E3D. Certain semblent résoudre le problème en allant à de haute vitesse (de l'ordre de 108mm/s).
Re: Sous extrusion e3dv6 bowden November 17, 2016 02:16PM |
Re: Sous extrusion e3dv6 bowden November 17, 2016 05:02PM |
Re: Sous extrusion e3dv6 bowden November 17, 2016 05:18PM |
Haldahir
Si je relis le troubleshooting (http://wiki.e3d-online.com/wiki/E3D-v6_Troubleshooting) de E3D dans ce sens, je comprend que ce heat creep peut être lié à un probleme de refroidissement (notamment des couches basses de l'échangeur en alu).
Il est assez froid chez moi mais:
- Mon gcode fait une rétractation importante à la fin de l'impression, ce qui explique peut qu'une impression sur 2 est galère vu que ca forme un bouchon.
- J'utilise le ventilo d'origine et c'est vrai que les couches basses du sapin (échangeur en alu) sont peu alimentée en air.
Re: Sous extrusion e3dv6 bowden November 18, 2016 04:34AM |
Re: Sous extrusion e3dv6 bowden December 30, 2016 03:13PM |
Re: Sous extrusion e3dv6 bowden December 30, 2016 04:34PM |
