Decalage table après chauffe hotend July 19, 2017 06:58AM |
Re: Decalage table après chauffe hotend July 20, 2017 03:52AM |
Admin Registered: 11 years ago Posts: 2,569 |
Re: Decalage table après chauffe hotend July 24, 2017 01:21PM |
; generated by Slic3r 1.2.9 on 2017-06-19 at 22:13:50 ; external perimeters extrusion width = 0.50mm ; perimeters extrusion width = 0.85mm ; infill extrusion width = 1.02mm ; solid infill extrusion width = 0.85mm ; top infill extrusion width = 0.28mm M107 M104 S210 ; set temperature G28 ; home all axes G1 Z5 F5000 ; lift nozzle M109 S210 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 G1 E-6.00000 F7200.00000 G92 E0 G1 Z0.200 F6000.000 G1 X54.372 Y61.087 F6000.000 G1 E6.00000 F7200.00000 G1 X54.969 Y60.578 E6.02097 F720.000 G1 X55.866 Y59.926 E6.05062 ... ... ... G1 E0.01122 F7200.00000 G92 E0 M107 M104 S0 ; turn off temperature G28 X0 ; home X axis M84 ; disable motors ; filament used = 407.3mm (1.0cm3) ; avoid_crossing_perimeters = 0 ; bed_shape = 0x0,150x0,150x150,0x150 ; bed_temperature = 0 ; before_layer_gcode = ; bridge_acceleration = 0 ; bridge_fan_speed = 100 ; brim_width = 0 ; complete_objects = 0 ; cooling = 1 ; default_acceleration = 0 ; disable_fan_first_layers = 1 ; duplicate_distance = 6 ; end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors ; extruder_clearance_height = 20 ; extruder_clearance_radius = 20 ; extruder_offset = 0x0 ; extrusion_axis = E ; extrusion_multiplier = 0.9 ; fan_always_on = 0 ; fan_below_layer_time = 60 ; filament_colour = #FFFFFF ; filament_diameter = 1.75 ; first_layer_acceleration = 0 ; first_layer_bed_temperature = 0 ; first_layer_extrusion_width = 200% ; first_layer_speed = 30% ; first_layer_temperature = 210 ; gcode_arcs = 0 ; gcode_comments = 0 ; gcode_flavor = reprap ; infill_acceleration = 0 ; infill_first = 0 ; layer_gcode = ; max_fan_speed = 100 ; max_print_speed = 80 ; max_volumetric_speed = 0 ; min_fan_speed = 35 ; min_print_speed = 10 ; min_skirt_length = 0 ; notes = ; nozzle_diameter = 0.5 ; only_retract_when_crossing_perimeters = 1 ; ooze_prevention = 0 ; output_filename_format = [input_filename_base].gcode ; perimeter_acceleration = 0 ; post_process = ; pressure_advance = 0 ; resolution = 0 ; retract_before_travel = 2 ; retract_layer_change = 1 ; retract_length = 6 ; retract_length_toolchange = 10 ; retract_lift = 0 ; retract_restart_extra = 0 ; retract_restart_extra_toolchange = 0 ; retract_speed = 120 ; skirt_distance = 6 ; skirt_height = 1 ; skirts = 3 ; slowdown_below_layer_time = 30 ; spiral_vase = 0 ; standby_temperature_delta = -5 ; start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle ; temperature = 210 ; threads = 2 ; toolchange_gcode = ; travel_speed = 100 ; use_firmware_retraction = 0 ; use_relative_e_distances = 0 ; use_volumetric_e = 0 ; vibration_limit = 0 ; wipe = 1 ; z_offset = 0 ; dont_support_bridges = 1 ; extrusion_width = 0 ; first_layer_height = 0.2 ; infill_only_where_needed = 0 ; interface_shells = 0 ; layer_height = 0.2 ; raft_layers = 0 ; seam_position = aligned ; support_material = 0 ; support_material_angle = 0 ; support_material_contact_distance = 0.2 ; support_material_enforce_layers = 0 ; support_material_extruder = 1 ; support_material_extrusion_width = 0 ; support_material_interface_extruder = 1 ; support_material_interface_layers = 0 ; support_material_interface_spacing = 0 ; support_material_interface_speed = 100% ; support_material_pattern = rectilinear ; support_material_spacing = 2.5 ; support_material_speed = 40 ; support_material_threshold = 0 ; xy_size_compensation = 0 ; bottom_solid_layers = 3 ; bridge_flow_ratio = 1 ; bridge_speed = 60 ; external_fill_pattern = rectilinear ; external_perimeter_extrusion_width = 0 ; external_perimeter_speed = 70% ; external_perimeters_first = 0 ; extra_perimeters = 1 ; fill_angle = 90 ; fill_density = 40% ; fill_pattern = honeycomb ; gap_fill_speed = 20 ; infill_every_layers = 1 ; infill_extruder = 1 ; infill_extrusion_width = 0 ; infill_overlap = 15% ; infill_speed = 50 ; overhangs = 1 ; perimeter_extruder = 1 ; perimeter_extrusion_width = 0 ; perimeter_speed = 30 ; perimeters = 3 ; small_perimeter_speed = 30 ; solid_infill_below_area = 70 ; solid_infill_every_layers = 0 ; solid_infill_extruder = 1 ; solid_infill_extrusion_width = 0 ; solid_infill_speed = 50 ; thin_walls = 1 ; top_infill_extrusion_width = 140% ; top_solid_infill_speed = 40 ; top_solid_layers = 3
# generated by Slic3r 1.2.9 on Tue Jul 4 15:00:11 2017 bed_temperature = 0 bridge_fan_speed = 100 cooling = 1 disable_fan_first_layers = 1 extrusion_multiplier = 0.9 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #FFFFFF filament_diameter = 1.75 first_layer_bed_temperature = 0 first_layer_temperature = 210 max_fan_speed = 100 min_fan_speed = 35 min_print_speed = 10 slowdown_below_layer_time = 30 temperature = 210
# generated by Slic3r 1.2.9 on Tue Jul 4 15:00:01 2017 avoid_crossing_perimeters = 0 bottom_solid_layers = 3 bridge_acceleration = 0 bridge_flow_ratio = 1 bridge_speed = 60 brim_width = 0 complete_objects = 0 default_acceleration = 0 dont_support_bridges = 1 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0 external_perimeter_speed = 70% external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0 fill_angle = 90 fill_density = 40% fill_pattern = honeycomb first_layer_acceleration = 0 first_layer_extrusion_width = 200% first_layer_height = 0.2 first_layer_speed = 30% gap_fill_speed = 20 gcode_comments = 0 infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 50 interface_shells = 0 layer_height = 0.2 max_print_speed = 80 max_volumetric_speed = 0 min_skirt_length = 0 notes = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 1 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_speed = 30 perimeters = 3 post_process = raft_layers = 0 resolution = 0 seam_position = aligned skirt_distance = 6 skirt_height = 1 skirts = 3 small_perimeter_speed = 30 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 50 spiral_vase = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_extruder = 1 support_material_interface_layers = 0 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = rectilinear support_material_spacing = 2.5 support_material_speed = 40 support_material_threshold = 0 thin_walls = 1 threads = 2 top_infill_extrusion_width = 140% top_solid_infill_speed = 40 top_solid_layers = 3 travel_speed = 100 xy_size_compensation = 0
# generated by Slic3r 1.2.9 on Tue Jul 4 15:03:53 2017 bed_shape = 0x0,150x0,150x150,0x150 before_layer_gcode = end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors extruder_offset = 0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.4 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2 retract_layer_change = 1 retract_length = 6 retract_length_toolchange = 10 retract_lift = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 120 start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 0 use_volumetric_e = 0 vibration_limit = 0 wipe = 1 z_offset = 0
Re: Decalage table après chauffe hotend July 25, 2017 04:52AM |
; start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\nM109 S210 ; wait for temperature to be reached\nG28 ; home all axes again
Re: Decalage table après chauffe hotend July 25, 2017 05:06AM |
Re: Decalage table après chauffe hotend July 25, 2017 06:58AM |
Re: Decalage table après chauffe hotend July 25, 2017 07:34AM |
Re: Decalage table après chauffe hotend July 25, 2017 11:36AM |
