Calibration 3DTouch impossible
Posted by Thierry72
December 15, 2018 06:52AM
Bonsoir à tous.
J'ai installé un 3DTouch, configuré et téléversé Marlin dans l'Arduino+Ramps de mon Anet A6.
Que ce soit dans Pronterface ou sur le panneau de commande de mon imprimante, le 3DTouch s'allume, s'autoteste, de déploie et se replie.
Mais quand je veux le calibrer, je n'y arrive pas.
Je commence par faire un Auto Home dans Pronterface.
Qui me renvoie ceci :
onnecting...
start
Printer is now online.
echo:Marlin 1.1.9
echo: Last Updated: 2018-08-01 | Author: (Ralf_E, ANET A6 config)
echo:Compiled: Dec 15 2018
echo: Free Memory: 3336 PlannerBufferBytes: 1232
echo:V55 stored settings retrieved (655 bytes; crc 6610)
echo: G21 ; (mm)
echo: M149 C ; Units in Celsius
echo:Filament settings: Disabled
echo: M200 D1.75
echo: M200 D0
echoconfused smileyteps per unit:
echo: M92 X100.00 Y100.00 Z400.00 E95.00
echo:Maximum feedrates (units/s):
echo: M203 X400.00 Y400.00 Z4.00 E25.00
echo:Maximum Acceleration (units/s2):
echo: M201 X9000 Y5000 Z50 E10000
echo:Acceleration (units/s2): P R T
echo: M204 P1000.00 R1000.00 T1000.00
echo:Advanced: Q S T X Y Z E
echo: M205 Q20000 S0.00 T0.00 X10.00 Y10.00 Z0.30 E5.00
echo:Home offset:
echo: M206 X0.00 Y0.00 Z0.00
echo:Auto Bed Leveling:
echo: M420 S0 Z0.00
echo:Material heatup parameters:
echo: M145 S0 H200 B50 F0
echo: M145 S1 H230 B70 F0
echotongue sticking out smileyID settings:
echo: M301 P49.07 I3.94 D152.84
echo: M304 P295.00 I35.65 D610.21
echo:Z-Probe Offset (mm):
echo: M851 Z0.00
echoconfused smileyD card ok
A priori tout va bien.
Puis quand je fais un "Home", j'ai ce retour :
echo:busy: processing
Errorconfused smileyTOP called because of BLTouch error - restart with M999
[ERROR] Errorconfused smileyTOP called because of BLTouch error - restart with M999
Errortongue sticking out smileyrinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
[ERROR] Errortongue sticking out smileyrinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting
Les axes ont trouvé leur Endstop, la tête est revenue au centre du plateau, et elle est montée. Le 3DTouch est allumé, capteur rentré.
Sur l'écran de l'imprimante si je sélectionne Préparer/Regl.Niv.lit, X et Y viennent au contact de leur EndStop puis se placent au centre du plateau, Z monte, le 3DTouch s'allume, bras rentré et l'écran affiche "Origine Z Premier".
Si je choisis sur l'écran de l'imprimante Regl.Niv.Lit, la tête d'impression fait un Homing, monte, le 3DTouch se déploie puis se replie.
Donc j'ai dû louper quelque chose quelque part, mais quoi ?
Thierry
Edited 2 time(s). Last edit at 12/15/2018 12:36PM by Thierry72.
open | download - Configuration.h (78 KB)
Re: Calibration 3DTouch impossible
December 20, 2018 03:52PM
Le forum semble perplexe.
December 23, 2018 07:09PM
J'ai regardé votre configuration.h, vous n'avez pas activé le BLtouch, vous n'avez pas défini de sonde x, y, z, il est normal que le toucher 3D ne fonctionne pas.
December 28, 2018 12:36PM
OK pour le BLTouch.
Je n'ai pas compris quelles sondes il faut définir.
Thierry
