Comment afficher sur l'écran LCD que la carte sd est insérée ou pas ? November 02, 2019 02:37PM |
#if ENABLED(SDSUPPORT) // Some RAMPS and other boards don't detect when an SD card is inserted. You can work // around this by connecting a push button or single throw switch to the pin defined // as SD_DETECT_PIN in your board's pins definitions. // This setting should be disabled unless you are using a push button, pulling the pin to ground. // Note: This is always disabled for ULTIPANEL (except ELB_FULL_GRAPHIC_CONTROLLER). #define SD_DETECT_INVERTED #define SD_FINISHED_STEPPERRELEASE true // Disable steppers when SD Print is finished #define SD_FINISHED_RELEASECOMMAND "M84 X Y Z E" // You might want to keep the Z enabled so your bed stays in place. // Reverse SD sort to show "more recent" files first, according to the card's FAT. // Since the FAT gets out of order with usage, SDCARD_SORT_ALPHA is recommended. #define SDCARD_RATHERRECENTFIRST #define SD_MENU_CONFIRM_START // Confirm the selected SD file before printing //#define MENU_ADDAUTOSTART // Add a menu option to run auto#.g files #define EVENT_GCODE_SD_STOP "G28XY" // G-code to run on Stop Print (e.g., "G28XY" or "G27")Mais avec le dernier Marlin bugfix je n'ai pas le message.
