Pâtés à l'impression April 22, 2020 05:07PM |
# generated by Slic3r 1.3.0-dev on Sat Feb 1 16:49:46 2020 avoid_crossing_perimeters = 1 bed_shape = 8x2,228x2,228x222,8x222 bed_temperature = 62 before_layer_gcode = bottom_solid_layers = 3 bridge_acceleration = 0 bridge_fan_speed = 100 bridge_flow_ratio = 1 bridge_speed = 60 brim_width = 0 complete_objects = 0 cooling = 1 default_acceleration = 0 disable_fan_first_layers = 3 dont_support_bridges = 1 duplicate_distance = 6 end_gcode = G1 E-30 F300 ; retrait filament\nM104 S0 ; turn off temperature\nM140 S0 ; temperature plateau\nG28 X0 ; home X axis\nM84 ; disable motors\n ensure_vertical_shell_thickness = 0 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0 external_perimeter_speed = 50% external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extruder_offset = 0x0 extrusion_axis = E extrusion_multiplier = 1 extrusion_width = 0 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #FFFFFF filament_diameter = 1.75 filament_max_volumetric_speed = 0 filament_notes = "" fill_angle = 45 fill_density = 15% fill_pattern = honeycomb first_layer_acceleration = 0 first_layer_bed_temperature = 67 first_layer_extrusion_width = 200% first_layer_height = 0.4 first_layer_speed = 30 first_layer_temperature = 210 gap_fill_speed = 20 gcode_arcs = 0 gcode_comments = 0 gcode_flavor = reprap infill_acceleration = 0 infill_every_layers = 10 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 80 interface_shells = 0 layer_gcode = layer_height = 0.3 max_fan_speed = 100 max_print_speed = 80 max_volumetric_extrusion_rate_slope_negative = 0 max_volumetric_extrusion_rate_slope_positive = 0 max_volumetric_speed = 0 min_fan_speed = 35 min_print_speed = 10 min_skirt_length = 0 notes = nozzle_diameter = 0.4 octoprint_apikey = octoprint_host = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 1 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_speed = 60 perimeters = 3 post_process = pressure_advance = 0 raft_layers = 0 resolution = 0 retract_before_travel = 2 retract_layer_change = 0 retract_length = 2 retract_length_toolchange = 10 retract_lift = 0.2 retract_lift_above = 0 retract_lift_below = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 40 seam_position = aligned serial_port = serial_speed = 250000 skirt_distance = 6 skirt_height = 1 skirts = 1 slowdown_below_layer_time = 5 small_perimeter_speed = 15 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 20 spiral_vase = 0 standby_temperature_delta = -5 start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n support_material = 0 support_material_angle = 0 support_material_buildplate_only = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = pillars support_material_spacing = 2.5 support_material_speed = 60 support_material_threshold = 0 support_material_with_sheath = 1 temperature = 205 thin_walls = 1 threads = 2 toolchange_gcode = top_infill_extrusion_width = 0 top_solid_infill_speed = 15 top_solid_layers = 3 travel_speed = 180 use_firmware_retraction = 0 use_relative_e_distances = 0 use_volumetric_e = 0 wipe = 0 xy_size_compensation = 0 z_offset = 0
Re: Pâtés à l'impression April 22, 2020 06:51PM |
Re: Pâtés à l'impression April 23, 2020 04:45AM |
[RESOLU] Pâtés à l'impression April 25, 2020 03:39AM |
Re: [RESOLU] Pâtés à l'impression May 01, 2020 04:38AM |
Re: [RESOLU] Pâtés à l'impression May 02, 2020 02:01AM |
Re: [RESOLU] Pâtés à l'impression May 10, 2020 09:01AM |
Re: [RESOLU] Pâtés à l'impression May 12, 2020 04:27AM |
Re: [RESOLU] Pâtés à l'impression July 29, 2020 04:34AM |
