Hi, new Prusa i3 printer. Had it a while, just recently assembled it.
3dprinting.com]
Does anyone know if the extruder motor gets wired the same as the other motors? Mine is different, 1-2-3-4 to 1-3-4-6, vs 1-3-2-4 to 1-3-4-6.
I can't get it to extrude.
Should the extruder have the middle wires swapped also?
With the nozzle removed, and cold, I can't get the extruder motor to advance to test it. Does the nozzle pad need to be hot to manually advance and check extruder motor operation?
Thanks
CrossRoads, in Marlboro
