Impresora 3D delta
February 03, 2015 06:27PM
Hola a todos, estoy vendiendo una Impresora 3d -180 Complete Assembly Delta. La impresora esta nueva. Quien este interesado por favor contactarme para mas informaciĆ³n.
Gracias
La impresora esta publicada en MercadoLibre en el siguiente link; [articulo.mercadolibre.com.co]
Technical parameters:
1, the printing technology: the accumulation of fused deposition molding (FDM)
2, physical structure, parallel arm (delta)
3, overall dimensions: height:600 mm width:320 mm length:320 mm 4, the total weight: 10 kg (including packaging)
5, external frame: imported aluminum, steel (laser precision cutting)
6, extruder:remotely and high-speed extrusion machine
7, the print head material: copper, aluminum, polyether ether ketone material forming
8, nozzle diameter: 0.4 mm (18, J - head hotend)
9 nozzle number: single nozzle
10 and the data format: STL
11, software: Repetier host
12, print range: 160 mm diameter hight 230 mm
13, power input: AC110-220 - v
14, the power supply output: DC 12 v 7 a
15,print plate: high borosilicate glass 180 mm in diameter
16, synchronous belt wheel / 16 teeth, belt GT2
17, equipped with LCD screen
The performance parameters
1, print thickness of 0.05 mm to 4 mm
, 2, mechanical precision is 0.0125mm
3, the operating system, Windows/Mac/Linux
, 4, high-speed USB device interface or SD card
Shipping list:
1, 3 d DLT - 180 delta printer (fully assembled)
2, the power supply 1 (12 v 7 a)
3,USB cable 1
4, print the test material to 100 grams
open | download - impresora-3d-dlt-180-complete-assembly-delta-22966-MCO20238731403_022015-O[1].jpg (23 KB)
