Reprap host hangs October 22, 2011 10:45AM |
C:\Program Files\Reprap>rem reprap-host -- runs Reprap Java host code with an ap propriate classpath C:\Program Files\Reprap>rem Amount of RAM to allow Java VM to use C:\Program Files\Reprap>set REPRAP_RAM_SIZE=1024M C:\Program Files\Reprap>rem reprap.jar file and stl file C:\Program Files\Reprap>set REPRAP_DIR=C:\Program Files\Reprap C:\Program Files\Reprap>rem Java3D and j3d.org libraries C:\Program Files\Reprap>rem set JAVA_LIBRARY_DIR=C:\Program Files\Reprap C:\Program Files\Reprap>rem cd so we can find the reprap-wv.stl file. Can we av oid this?? C:\Program Files\Reprap>IF NOT EXIST reprap-wv.stl cd "C:\Program Files\Reprap" C:\Program Files\Reprap>java -cp ".\reprap.jar;.\RXTXcomm.jar;.\j3dcore.jar;.\j3 d-org-java3d-all.jar;.\j3dutils.jar;.\swing-layout-1.0.3.jar;.\vecmath.jar;." -X mx1024M org/reprap/Main DEBUG: The distribution preferences file and yours match. This is good. [0,003s /-1319293115782ms] DEBUG: GCode opening port COM2 [0,064s/61ms] Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 comms: G-code: N0 M110 *3 dequeued and sent [4,218s/4154ms]
Re: Reprap host hangs October 23, 2011 09:14AM |
Re: Reprap host hangs October 24, 2011 05:14AM |
