Where is Z Min Position
Posted by emt
emt
March 23, 2008 06:03AM
Hi
Using single Arduino electronics
I am hoping to use an existing CNC mill with an extruder mounted.
I am currently setting it up.
Which is the Z min position? Is this at the top of Z the stroke?
I have it set this way but when I home using stepper excerciser it ignores the upper microswitch but stops if I press the lower switch.
It may be I have the switches the wrong way round.
All switches are working when using the switch test software.
Regards
Ian
emt
Re: Where is Z Min Position
March 23, 2008 12:53PM
Hi
Answering my own question.
The switches are correct but I had the axis travelling the wrong way. I read the cartesian instructions forgetting that the equivilant to my head lowering is the Darwin table rising. I was expecting the Z home to be at the top of slide travel i.e. as far away from the table as possible as this is the norm for CNC machines.
Regards
Ian
