Hi
Using single Arduino electronics
I am hoping to use an existing CNC mill with an extruder mounted.
I am currently setting it up.
Which is the Z min position? Is this at the top of Z the stroke?
I have it set this way but when I home using stepper excerciser it ignores the upper microswitch but stops if I press the lower switch.
It may be I have the switches the wrong way round.
All switches are working when using the switch test software.
Regards
Ian
