Pronterface set position as home?
Posted by shippo0708
December 05, 2011 05:13PM
I'm using a Sanguinololu with pronterface and i was wondering how i can manually home the axis? i don't use endstops and when i try to print something i guess the Z thinks its too low so it raises up far above the bed before it starts printing... which results in a blob leaking from the air....
The frame I'm working with is a ZenToolworks 7x7 3D Printer model
Re: Pronterface set position as home?
February 22, 2012 10:57PM
shippo0708,
I am having the same problem. Did you ever find a solution?
Thomas
February 24, 2012 12:11PM
As painful as it sounds, the only way I have been able to do this (I have not figured out how to use these stupid endstops either) is to take the print head to where I think home should be. Then disconnect/reconnect from/to pronterface. I then have to reset the bed and heater temperatures before they fall too far. I'm ready to print from there.
February 27, 2012 06:40AM
You might have success adding that gcode in the start sequence :
G92 X0 Y0 Z0 E0
