Which Software for Arduino electronics
Posted by emt
emt
May 11, 2008 05:15AM
Hi
Is any one successfully using the Arduino set up with the standard host (ie not G code)?
If so can you advise which version of firmware and which version of host?
Also a zipped version of your preferences would be helpful.
I am at the stage of trying to print and have strange things happening which at present make no sense to me at all. I have a hybrid machine with 2000 step micro steppers which may be an issue but first I think I must make sure I am using a compatible set of software that is known to work which I can try with the settings that are known to work.
I can then change to my settings 1 step at a time to help resolve the issue.
Regards
Ian
Re: Which Software for Arduino electronics
May 14, 2008 04:51AM
Ian,
Any photos or drawings of what is happening on your tray?
Adam
May 16, 2008 01:43PM
ian,
always use the latest version of the arduino firmware. the single_arduino_snap is the recommended one to use.
i'll be releasing a new version this weekend with some minor fixes, but its certainly usable.
emt
May 17, 2008 10:23AM
Hi Zach
Is this Adrians Firmware 30/04/08 Revision 1549 or yours 2/04/08 Rev 1472?
Also which Host, the latest on the trunk?
Sorry to be so pedantic but I am getting some strange behaviour which could well be my set up being a hybrid with micro stepping drives and fine screws which gives a fairly high step frequency.
Regards
Ian
May 22, 2008 06:55PM
if you're not comfortable with hacking around in the code, i'd recommend using the latest version of the firmware/software from sourceforge. the subversion stuff is usually stable, but not always.
