I have changed the names of a few things in the properties file to add their dimensions:
Extruder0_NozzleWipeDatum
mm)
Extruder0_NozzleWipeDatumY(mm)
Extruder0_NozzleWipeStroke(mm)
Extruder0_ShortLength(mm)
Extruder0_ShortSpeed(0..1)
And added a new number to play with:
Extruder0_InfillOverlap(mm)
This defaults to 0, when it has no effect. But if you put a number in it, the infill hatch will overlap by that many mm with the outline; this allows you to stick them together tighter, but doing it too much will cause distortion, of course. Negative values will create a gap.
(There are corresponding ones for Extruder1_xxxx, of course).
best wishes
Adrian
reprap.org]
reprapltd.com]
