reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 13, 2008 09:32PM |
Thanks for your help
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 13, 2008 09:39PM |
mm)=15
mm)=20
mm)=20
mm)=0
mm)=300
mm)=15
mm)=0
mm)=-17.3|
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 13, 2008 09:41PM |
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 14, 2008 10:10AM |
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 14, 2008 06:20PM |
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 16, 2008 09:29AM |
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 16, 2008 10:45AM |
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 16, 2008 11:47PM |
That was the problem. Now, cool iced water gives 5C (probably wasn't in thermal equilibrium yet) and boiling water gives 96C. Yay.
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 17, 2008 09:15AM |
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 17, 2008 10:09PM |
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 24, 2008 01:38PM |
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 24, 2008 09:30PM |
The values in ThermistorTable.h are supposed to reflect the actual physical thermistor used, while the values in reprap.properties are supposed to be set to certain values no matter what thermistor you use (if you're using an Arduino based system). It's confusing, and should be addressed.
Re: reprap-host's Extruder excerciser gives wrong temperature but testing code worked June 25, 2008 06:47AM |
The values in
