Errors and pronterface
Posted by Anthrochick
August 17, 2012 03:44PM
Okay, so after trying to manually install all the software like it says on the wiki, I was only able to run pronterface from the command line. I figured maybe it was a Java issue so I uninstalled the latest java and installed 5. I tried to run the reprap.bat file and recieved an error message: Errorlevel 1 pause... Does anyone know how to fix this? I feel like there's something obvious I'm missing but I just can't think straight right now. Is this just a Java issue since it also says that it can't find the main class? I'm not too familiar with Java, btw, python is more my thing.
Re: Errors and pronterface
August 17, 2012 05:50PM
Pronterface does NOT use Java at all, it is written in Python. Java is only needed if you want to use Host, which does what pronterface and a slicing program do together. So you can debug the pronterface problem as a python problem.
August 17, 2012 06:39PM
Thank You! I thought I was going crazy!
Bringing 3D printing to America's classrooms.
Follow my efforts at TheChicksNest.blogspot.com
October 22, 2012 02:06AM
Im having a problem. When I turned off any switch(not the 1 to which printer is connected), my printer stops working.
