What does the flow-rate ruler do ?
Posted by Replace
October 23, 2014 05:17AM
In my Repetier host, I have a few rulers
At start they are at 100
flow rate is one of them
what happens when I increase or decrease that value during print ?
I mean.. is it separate from other speeds ? Just more plastic in the same time ?
And what I fI increase only the displacement speed ?
No influence on the plastic flow , or will things increase in relevant order with other speeds ?
Thomas
p.s. I come from Pronterface, where those values were fixed
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: What does the flow-rate ruler do ?
November 08, 2017 04:40AM
If you increase the "flow rate" you increase the amount of filament extruded, decrease then decrease the filament.
