Single_Arduinos_SNAP won't compile,
Posted by stmaus
July 27, 2008 09:46AM
I'm trying to compile and load v1.3 and I'm getting this message from the Arduino Compiler.
o: In function `setup':
undefined reference to `SNAP::begin(long)'o: In function `loop':
I'm not a very good coder so I'm not able to fix this myself. Has anyone else solved this?
Re: Single_Arduinos_SNAP won't compile,
July 27, 2008 10:56AM
It seems to be working for me. I downloaded the 1.3 firmware, opened Single_Arduino_SNAP.pde which started up the Arduino "0011 Alpha" development environment. I was able to download the program to the Arduino Diecimila. I got a "Can't determine program size" error the first few times I verified (compiled) but after downloading to the Arduino that error did not repeat.
When I run the serial monitor at 19200 baud I see a "dBEGIN\n" message each time I reset the Arduino.
I think there was a step I had to do the first time I downloaded the RepRap firmware. The contents of the reprap-ardiuno-firmware_1.3/library directory must be copied to the arduino-0011/hardware/libraries directory that is part of the Arduino install.
