First attempt at printing gives "Production complete" message after 6.5 seconds
Posted by Andromodon
July 29, 2008 10:59PM
Hello. I am working on the "Software Tweaking" page of the Darwin build instructions [www.reprap.org]. Specifically, I am in the "Measure the deposited filament section" area of the page, which instructs me to, for the first time with this machine, print a .stl file, widebar.stl.
After setting the parameters as specified (Except that I used 210C for a extrusion temp, as I am using HDPE), closing the program, opening it, loading the widebar.stl file, selecting "HDPE", and clicking "Start build", my RepRap is motionless. About 7 seconds later, I get the following message:
Apparently, the reprap-host software thinks it finished the whole job in 6.5 seconds. Wouldn't that be nice? smiling smiley
Any ideas about what the problem is?
Some facts, as I understand them:
1.) I am using the latest released reprap-host software, reprap-host-20080523.zip
2.) I am using the reprap single-Arduino SNAP file from reprap-arduino-firmware-1.3.zip
3.) The stepper motor exerciser works when I start up the reprap-host program fresh, and I am able to control each stepper.
4.) The extruder exerciser works when I start up the reprap-host program fresh, and I am able to heat, sense temperature, and extrude.
5.) On a typical run of reprap-host, doing things like 3 and 4, I usually get the following console messages:
$ reprap-host
Experimental: JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
Exception in thread "RepRap" java.lang.NullPointerException
at javax.swing.ImageIcon.(ImageIcon.java:138)
at org.reprap.gui.botConsole.PrintTabPanel.initComponents(Unknown Source)
at org.reprap.gui.botConsole.PrintTabPanel.(Unknown Source)
at org.reprap.gui.botConsole.BotConsoleFrame.initComponents(Unknown Source)
at org.reprap.gui.botConsole.BotConsoleFrame.(Unknown Source)
at org.reprap.gui.botConsole.BotConsoleFrame$1.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:273)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:183)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:173)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:168)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:160)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:121)
sendMessage error - retrying
Everything before the sendMessage errors happens on startup, and the sendMesage errors happen usually when I'm doing something like telling it to extrude or run a motor. These errors are unpredictable. On a given program run, I may get 0 or I may get 10. Usually, they come one at a time.
Are these sendMessage errors normal? The retries seem to work fine, and the cumulative effect seems to just be a delay in the robot's response.
6. Sometimes when I try to print the stl file, I get only the errors mentioned above. Other times, I've gotten a slew of the following errors:
at org.reprap.comms.snap.SNAPCommunicator.receivePacket(Unknown Source)
at org.reprap.comms.snap.SNAPCommunicator.sendMessage(Unknown Source)
at org.reprap.comms.IncomingMessage.(Unknown Source)
at org.reprap.devices.GenericExtruder$RequestIsEmptyResponse.(Unknown Source)
at org.reprap.devices.GenericExtruder.RefreshEmptySensor(Unknown Source)
at org.reprap.devices.GenericExtruder.TEMPpollcheck(Unknown Source)
at org.reprap.devices.GenericExtruder.getTemperature(Unknown Source)
at org.reprap.gui.botConsole.GenericExtruderTabPanel.refreshTemperature(Unknown Source)
at org.reprap.gui.botConsole.GenericExtruderTabPanel.access$100(Unknown Source)
at org.reprap.gui.botConsole.GenericExtruderTabPanel$1.run(Unknown Source)
7. I have tried shutting down the RepRap, resetting the Arduino, turning the RepRap back on, and starting reprap-host again. Same 6-second print.
Any thoughts? Has this happened to anyone else? Thanks for your help.
Wow... It seems like someone else, just a little while ago, had the same problem as I did. [forums.reprap.org]
Changing nullcartesian to cartesian in my preferences fixed the problem. What is nullcartesian for, anyway, and why is it the default? smiling smiley
Also, if anyone has any insight into the errors I get, I would greatly appreciate hearing it. smiling smiley
~Andy
Some other errors I've gotten:
When setting the Extruder0_XYSpeed to 255, and trying to print the above stl, the machine starts printing, then stops, and eventually outputs:
IO error/timeout, resending
Printing at the 247 speed works fine.
Another error I've gotten:
Exception in thread "Producer" java.lang.StackOverflowError
at org.reprap.geometry.polygons.treeList.getChild(Unknown Source)
at org.reprap.geometry.polygons.treeList.setParents(Unknown Source)
Just thought I should post them as a sort of bug report. smiling smiley
Ru
Re: First attempt at printing gives "Production complete" message after 6.5 seconds
July 30, 2008 03:03AM
It just does a build preview, and no actual IO. It means the software can run and be tested without needing a real cartesian bot attached to it.
