posting from my mobile, but if you're using a single arduino, there's not enough pins for the enable signal to be used on all axis. It works fine if you turn down the current limiting pot on the stepper driver board. Been running my Darwin like that for a month. Use the lowest setting that will keep your z axis moving. Alternatively, free up a pin and tweak the software.
