Software problems - 'locking assertion failure' September 11, 2008 12:37PM |
root@ralph-laptop:/usr/lib/jvm# ls
java-1.5.0-sun java-1.5.0-sun-1.5.0.15 java-6-sun-1.6.0.06
root@ralph-laptop:/home/ralph/reprap-host-20080523# ./reprap-host.sh
Locking assertion failure. Backtrace:
#0 /usr/lib/libxcb-xlib.so.0 [0xb7f1a767]
#1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_unlock+0x31) [0xb7f1a8b1]
#2 /usr/lib/libX11.so.6(_XReply+0xfd) [0xb16921bd]
#3 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/xawt/libmawt.so [0xb1782dce]
#4 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/xawt/libmawt.so [0xb176cd77]
#5 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/xawt/libmawt.so [0xb176cef3]
#6 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/xawt/libmawt.so(Java_sun_awt_X11GraphicsEnvironment_initDisplay+0x26) [0xb176d136]
#7 [0xb25c9bfa]
#8 [0xb25c3b3b]
#9 [0xb25c3b3b]
#10 [0xb25c1219]
#11 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/libjvm.so [0xb77812bc]
#12 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/libjvm.so [0xb7895ed8]
#13 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/libjvm.so [0xb77810ef]
#14 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/libjvm.so(JVM_DoPrivileged+0x32d) [0xb77deb9d]
#15 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/libjava.so(Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedAction_2+0x3d) [0xb757530d]
#16 [0xb25c94ab]
#17 [0xb25c3a64]
#18 [0xb25c1219]
#19 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/libjvm.so [0xb77812bc]
#1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_lock+0x2e) [0xb7f1a81e]
#2 /usr/lib/libX11.so.6 [0xb1691518]
#3 /usr/lib/libX11.so.6(XGetVisualInfo+0x26) [0xb16880a6]
#4 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/xawt/libmawt.so [0xb176c0b9]
#5 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/xawt/libmawt.so [0xb176c303]
#6 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/xawt/libmawt.so [0xb176cfa1]
#7 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/xawt/libmawt.so(Java_sun_awt_X11GraphicsEnvironment_initDisplay+0x26) [0xb176d136]
#8 [0xb25c9bfa]
#9 [0xb25c3b3b]
#10 [0xb25c3b3b]
#11 [0xb25c1219]
#12 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/libjvm.so [0xb77812bc]
#13 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/libjvm.so [0xb7895ed8]
#14 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/libjvm.so [0xb77810ef]
#15 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/libjvm.so(JVM_DoPrivileged+0x32d) [0xb77deb9d]
#16 /usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/libjava.so(Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedAction_2+0x3d) [0xb757530d]
#17 [0xb25c94ab]
#18 [0xb25c3a64]
#19 [0xb25c1219]
Experimental: JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
java.lang.Exception:
Could not connect at /dev/ttyS0.
Check to make sure that is the right path.
Check that you have your serial connector plugged in.The program will continue but your geometry preference has been set to 'nullcartesian' for this session.
at org.reprap.Main.initComms(Unknown Source)
at org.reprap.Main.access$2200(Unknown Source)
at org.reprap.Main$22.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: javax/swing/GroupLayout$Group
Re: Software problems - 'locking assertion failure' September 11, 2008 05:28PM |
Re: Software problems - 'locking assertion failure' September 12, 2008 01:09PM |
