Repetier Host crashes before opening
Posted by fast1
December 21, 2012 11:10AM
Sir:
I certainly appreciate your wonderful software.
I apologize for the duplicate post. I originally posted this in Repetier, but believe that this is the correct location.
I started having problems tonight with my Slic3r configuration file. I was unable to update my configurations. I began reading posts and read somewhere that maybe my configuration file needed quotes in it. I did that and have not been able to open the program sense.
I put a quoted path and file name in the general configuration in Repetier Host.
I have tried reinstalling the program.
I then tried deleting the directory and reinstalling the program.
It is still crashing before opening.
I have tried using "Process Monitor" to see if I could find a configuration file, but all I see that Repetier Host is opening is DLL files. I have looked through the regestry for a key that might contain this file, but no luck. Is very difficult for me to fix because I can not open the program now.
I am sure that there is just some configuration file that needs deleting or changing but I can not
find it.
I would so much appreciate your help.
Fayette Sims
Re: Repetier Host crashes before opening
December 21, 2012 11:28AM
Sir:
I resolved this issue by deleting all the regestry values for the software I can now open the
program and hopefully use it.
Again thank you so much for such a wonderful program.
Fayette Sims
