Newbi - problems installing using windows
Posted by Alanog
March 25, 2013 02:55PM
Have followed all instructions but when I run the reprap.bat file the dos installer screen has a message to the effect that "java" is not a recognized command, program or batch file. There is a message on one of the help screens about copying java files to a reprap subfolder but I can't make sense of it. I have Java version 7.
johnk
Re: Newbi - problems installing using windows
March 27, 2013 07:01PM
you need to add the java program directory to your path variable. Go to control, system properties, advaced, environmental variables, find 'path', copy to notepad, add whatever your path to java is (usually c:\program files\java\jre7 or something like that - browse through c: drive to find it). Then, copy the variable back.
