G-code syntax December 21, 2008 12:37PM |
G-codes:
0 rapid positioning
1 linear interpolation uses XYZ+float and F+float
2 clockwise arc (uses I and J for center)
3 counterclockwise arc (uses I and J for center)
4 dwell P20 to wait 20 seconds
20 inches
21 mm
28 go reference point (home?)
30 go home via an intermediate point
90 absolute positioning (abs_mode = true
91 incremental positioning (abs_mode = false
92 set as home
93 Inverse Time Feed Mode (stubbed, not implemented)
94 Feed per Minute Mode (stubbed, not implemented)
and M-codes
0 stop program (stubbed, not implemented)
1 optional stop (stubbed, not implemented)
2 program end (stubbed, not implemented)
100 set max extruder speed, 0-255 pwm using "P"
101 extruder on, forward
102 extruder on, reverse
103 extruder off
104 set temperture control uses "P"
105 read temperature sends "T:" plus temp
106 turn fan on (pwm at 255)
107 turn fan off (pwm 0)
108 P[TEMP] - Dwell until extruder temperature reaches P (+-1 degrees). Also has the side effect of setting the target extruder temperature. (implicit M104)
109 uses P+float
110 uses p+float
111 ????
113 ????
Re: G-code syntax December 21, 2008 03:01PM |
Re: G-code syntax December 21, 2008 03:35PM |
Re: G-code syntax December 22, 2008 12:11AM |
Re: G-code syntax December 22, 2008 04:12AM |
Re: G-code syntax December 22, 2008 09:22AM |
Re: G-code syntax June 17, 2009 09:18AM |
Re: G-code syntax June 17, 2009 11:19AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: G-code syntax June 18, 2009 05:48AM |
Re: G-code syntax June 18, 2009 06:54AM |
Re: G-code syntax June 18, 2009 08:58AM |
