Running on my Ubuntu laptop at 1280 x 800 I get many examples of the following when I run the latest host software from the sourceforge zip file:
Note the buttons below the axis positions are only partially visible. It looks like the window layout is designed for a different window size but as there is no difference if I maximise the window (and others haven't complained) I doubt that is the case. It is probably something I'm doing or not doing.
Another example:
In this case it is just that the tops of the words are cut off. If you maximise the screen the variable names come right but the values in the boxes do not i.e. the input boxes are not tall enough.
It may or may not be related to a weird warning I get when I run the software:
Feb 20, 2009 10:03:43 AM com.sun.corba.se.impl.ior.IORImpl getProfile
WARNING: "IOP00511201: (INV_OBJREF) IOR must have at least one IIOP profile"
org.omg.CORBA.INV_OBJREF: vmcid: SUN minor code: 1201 completed: No
at com.sun.corba.se.impl.logging.IORSystemException.iorMustHaveIiopProfile(IORSystemException.java:473)
at com.sun.corba.se.impl.logging.IORSystemException.iorMustHaveIiopProfile(IORSystemException.java:495)
at com.sun.corba.se.impl.ior.IORImpl.getProfile(IORImpl.java:334)
at com.sun.corba.se.impl.encoding.CDRInputStream_1_0.read_Object(CDRInputStream_1_0.java:787)
at com.sun.corba.se.impl.encoding.CDRInputStream_1_0.read_Object(CDRInputStream_1_0.java:761)
at com.sun.corba.se.impl.encoding.CDRInputStream.read_Object(CDRInputStream.java:231)
at com.sun.corba.se.impl.resolver.INSURLOperationImpl.getIORFromString(INSURLOperationImpl.java:120)
at com.sun.corba.se.impl.resolver.INSURLOperationImpl.operate(INSURLOperationImpl.java:130)
at com.sun.corba.se.impl.orb.ORBImpl.string_to_object(ORBImpl.java:836)
at org.GNOME.Accessibility.AccessUtil.getRegistryObject(AccessUtil.java:143)
at org.GNOME.Accessibility.JavaBridge.registerApplication(JavaBridge.java:1099)
at org.GNOME.Accessibility.JavaBridge.(JavaBridge.java:364)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
at java.lang.Class.newInstance0(Class.java:372)
at java.lang.Class.newInstance(Class.java:325)
at java.awt.Toolkit.loadAssistiveTechnologies(Toolkit.java:786)
at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:874)
at java.awt.Toolkit.getEventQueue(Toolkit.java:1694)
at java.awt.EventQueue.invokeLater(EventQueue.java:957)
at javax.swing.SwingUtilities.invokeLater(SwingUtilities.java:1289)
at org.reprap.Main.main(Unknown Source)
Any ideas?
