OS X Netbeans - was RepRap Host software bug March 14, 2009 08:07PM |
Re: OS X Netbeans - was RepRap Host software bug March 15, 2009 01:07AM |
Experimental: JNI_OnLoad called. Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 Error opening port: /dev/ttyUSB0 Exception in thread "RepRap" java.lang.NoClassDefFoundError: org/jdesktop/layout/GroupLayout$Group at org.reprap.Main$9.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209) at java.awt.EventQueue.dispatchEvent(EventQueue.java:461) at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176) at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
RepRap preference: Extruder0_EvenHatchDirection(degrees) not found in either preference file. Refresh extruder preferences: java.lang.NullPointerException RepRap preference: Extruder0_EvenHatchDirection(degrees) not found in either preference file. Refresh extruder preferences: java.lang.NullPointerException Experimental: JNI_OnLoad called. Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 Error opening port: /dev/ttyUSB0 RepRap preference: Extruder0_EvenHatchDirection(degrees) not found in either preference file. Refresh extruder preferences: java.lang.NullPointerException java.lang.Exception: Cannot locate background STL file at org.reprap.gui.Panel3D.getStlBackground(Panel3D.java:523) at org.reprap.gui.RepRapBuild.createSceneBranchGroup(RepRapBuild.java:304) at org.reprap.gui.Panel3D.initJava3d(Panel3D.java:303) at org.reprap.gui.Panel3D.initialise(Panel3D.java:187) at org.reprap.gui.RepRapBuild.(RepRapBuild.java:225) at org.reprap.Main.createAndShowGUI(Main.java:348) at org.reprap.Main.access$1500(Main.java:50) at org.reprap.Main$9.run(Main.java:679) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209) at java.awt.EventQueue.dispatchEvent(EventQueue.java:461) at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176) at java.awt.EventDispatchThread.run(EventDispatchThread.java:110) Exception in thread "RepRap" java.lang.NoClassDefFoundError: org/jdesktop/layout/GroupLayout$Group at org.reprap.Main$9.run(Main.java:688) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209) at java.awt.EventQueue.dispatchEvent(EventQueue.java:461) at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176) at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
RepRap preference: Extruder0_EvenHatchDirection(degrees) not found in either preference file. Refresh extruder preferences: java.lang.NullPointerException RepRap preference: Extruder0_EvenHatchDirection(degrees) not found in either preference file. Refresh extruder preferences: java.lang.NullPointerException Experimental: JNI_OnLoad called. Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 Error opening port: /dev/ttyUSB0 RepRap preference: Extruder0_EvenHatchDirection(degrees) not found in either preference file. Refresh extruder preferences: java.lang.NullPointerException Exception in thread "RepRap" java.lang.NoClassDefFoundError: javax/media/opengl/GLException at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:164) at javax.media.j3d.Pipeline$1.run(Pipeline.java:162) at java.security.AccessController.doPrivileged(Native Method) at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:157) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:965) at javax.media.j3d.VirtualUniverse.(VirtualUniverse.java:299) at javax.media.j3d.GroupRetained.(GroupRetained.java:161) at javax.media.j3d.BranchGroupRetained.(BranchGroupRetained.java:55) at javax.media.j3d.BranchGroup.createRetained(BranchGroup.java:76) at javax.media.j3d.SceneGraphObject.(SceneGraphObject.java:119) at javax.media.j3d.Node.(Node.java:178) at javax.media.j3d.Group.(Group.java:556) at javax.media.j3d.BranchGroup.(BranchGroup.java:68) at org.reprap.gui.Panel3D.(Panel3D.java:86) at org.reprap.gui.RepRapBuild.(RepRapBuild.java:224) at org.reprap.Main.createAndShowGUI(Main.java:348) at org.reprap.Main.access$1500(Main.java:50) at org.reprap.Main$9.run(Main.java:679) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209) at java.awt.EventQueue.dispatchEvent(EventQueue.java:461) at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176) at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Re: OS X Netbeans - was RepRap Host software bug ![]() March 21, 2009 11:49PM |
