RepRap Software shows wrong temp from Thermistor
Posted by Al3x
March 31, 2009 02:52PM
Hi experts winking smiley
just working at my RepRap machine - but struggeling with a problem.
I am using the Temperatur Sensore 1.1 (http://reprap.org/bin/view/Main/Temperature_Sensor_1_1)
If I fire up the RepRap Software it shows me sth about 400 degree... kind of wrong (no power on the nichrome wire)
I didn't change the Gcode Interpreter source ?!?
Do you have any hints for me?
Best Regards from Germany
Alex
Re: RepRap Software shows wrong temp from Thermistor
March 31, 2009 04:20PM
If the thermistor is disconnected or there is a broken connection somewhere you get all kinds of numbers out.
But for that kind of number , check your thermistor type and the settings in the .h file in the arduino software. if you have the wrong beta values you can get wrong temps.
March 31, 2009 04:23PM
thanks, I will check and post tomorrow again
greetings alex
April 01, 2009 04:41AM
So it was mi fault I forgot to put the comment away in ThermistorTable.h
// Uncomment the next line if you are using a thermistor; leave it if you have a thermocouple
#define USE_THERMISTOR
Greetings
Alex
June 15, 2009 03:15PM
I have the same problem, but I uncommented it. Is there anything else it could be?
