Error on SVN
Posted by Grogyan
Error on SVN
June 14, 2009 03:34AM
FYI
I tried downloading, several times, from the subversion repository, after I finally found the SVN links, and with using Tortoise SVN, it reports that
[reprap.svn.sourceforge.net]
is locked and unversioned as well as the files with in it, now the whole directory structure cannot be fixed and refuses to update any further or clean up.
The link I am using to checkout the repository is
Any ideas on how I can fix it?
Edited 1 time(s). Last edit at 06/14/2009 03:41AM by Grogyan.
Re: Error on SVN
June 16, 2009 05:32AM
Doesn't anyone have an idea of how I can fix this?
Re: Error on SVN
June 18, 2009 02:30PM
Kintel has kindly fixed the error on SVN, apparently there was a conflict with two files with the same filename, but slightly different.
The difference was because of one file named as CSGEvaluator and another CSGEValuator, by having the "v" in uppercase, tortoise SVN (which I use) threw out errors.
Thanks
