aoi problem reading stl files June 19, 2007 03:48PM |
Re: aoi problem reading stl files June 19, 2007 04:00PM |
Admin Registered: 18 years ago Posts: 1,487 |
Re: aoi problem reading stl files June 19, 2007 04:04PM |
Re: aoi problem reading stl files June 19, 2007 04:45PM |
Admin Registered: 18 years ago Posts: 1,915 |
Anonymous User
Re: aoi problem reading stl files June 19, 2007 05:47PM |
Re: aoi problem reading stl files June 19, 2007 07:51PM |
Re: aoi problem reading stl files June 20, 2007 01:54PM |
Re: aoi problem reading stl files July 13, 2007 04:19AM |
Anonymous User
Re: aoi problem reading stl files July 13, 2007 07:54AM |
Re: aoi problem reading stl files July 13, 2007 08:50AM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: aoi problem reading stl files July 13, 2007 09:16AM |
Re: aoi problem reading stl files July 13, 2007 09:17AM |
Re: aoi problem reading stl files July 13, 2007 10:00AM |
Re: aoi problem reading stl files July 13, 2007 10:16AM |
Anonymous User
Re: aoi problem reading stl files July 13, 2007 11:14AM |
AoI auto-import behaviour July 13, 2007 07:41PM |
Admin Registered: 18 years ago Posts: 476 |
Re: aoi problem reading stl files July 14, 2007 03:27AM |
While you're in there... adding a way to cause AOI to load a file and then save/export it in another format from the command line would be very handy indeed
I've had the initial code, and great future plans, for a command-line interface to AOI for just over a year now. Recently someone asked to take it over (to help them with a different project), so hopefully Claoi (I pronounce it like "Chloe') should be released in a month or so.|
Re: aoi problem reading stl files July 14, 2007 03:41PM |
Re: aoi problem reading stl files July 14, 2007 04:30PM |
Re: aoi problem reading stl files July 16, 2007 10:38PM |
Well, I was thinking that many such users are at least somewhat comfortable with an office suite. You open a spreadsheet by double clicking on it. You edit it, you print it, you save it and the default file format is a ... spreadsheet [...]
Re: aoi problem reading stl files July 16, 2007 10:43PM |
Yes, sorry about that. My solution for the time the STL translator takes was to put a progress bar into the dialog.Quote
(after a slight delay!)
Re: aoi problem reading stl files July 16, 2007 11:46PM |
Re: aoi problem reading stl files July 16, 2007 11:55PM |
Re: aoi problem reading stl files July 16, 2007 11:56PM |
Re: aoi problem reading stl files July 17, 2007 09:26AM |
Re: aoi problem reading stl files July 17, 2007 10:03AM |
Re: aoi problem reading stl files September 20, 2007 12:36PM |
Re: aoi problem reading stl files September 20, 2007 04:07PM |
