designing a program setup wizard tool for reprap November 09, 2009 10:25PM |
Re: designing a program setup wizard tool for reprap November 10, 2009 12:52AM |
Re: designing a program setup wizard tool for reprap November 10, 2009 05:49AM |
Re: designing a program setup wizard tool for reprap November 10, 2009 04:19PM |
Re: designing a program setup wizard tool for reprap November 10, 2009 04:20PM |
Re: designing a program setup wizard tool for reprap November 12, 2009 03:27AM |
Re: designing a program setup wizard tool for reprap November 12, 2009 04:30AM |
Re: designing a program setup wizard tool for reprap November 12, 2009 05:49AM |
Re: designing a program setup wizard tool for reprap November 13, 2009 05:58AM |
Re: designing a program setup wizard tool for reprap November 13, 2009 07:21AM |
Re: designing a program setup wizard tool for reprap November 13, 2009 08:40AM |
Re: designing a program setup wizard tool for reprap November 13, 2009 09:09AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: designing a program setup wizard tool for reprap November 15, 2009 01:47AM |
Re: designing a program setup wizard tool for reprap November 15, 2009 10:44PM |
Re: designing a program setup wizard tool for reprap November 16, 2009 07:31AM |
Re: designing a program setup wizard tool for reprap November 16, 2009 06:32PM |
Re: designing a program setup wizard tool for reprap November 17, 2009 04:11AM |
So this is more a proof of concept version. what is cool is the installation file. it's a once stop installation that has it all. I doubt the java version will have anything but the wizard and the gui. The installation is huge due to including the programs to install, all these programs are used to some extent by my GUI. the setup wizard is part of the GUI though.|
Re: designing a program setup wizard tool for reprap November 19, 2009 06:36PM |
Re: designing a program setup wizard tool for reprap November 21, 2009 05:37AM |
Re: designing a program setup wizard tool for reprap November 21, 2009 06:23AM |
Re: designing a program setup wizard tool for reprap November 23, 2009 08:14PM |
Re: designing a program setup wizard tool for reprap November 23, 2009 09:16PM |
Admin Registered: 19 years ago Posts: 1,791 |
Re: designing a program setup wizard tool for reprap November 28, 2009 01:49AM |
Re: designing a program setup wizard tool for reprap November 29, 2009 04:50AM |
So looking forward to the beta! Since you are a BfB Rapman user please post this on the Bfb forum too.
Re: designing a program setup wizard tool for reprap November 29, 2009 04:44PM |
another issue is with draft mode thickness. I had exceeded extruder speed of my printer, so I had to go back in and say well if extruder can't keep up then lower federate. I'm trying to compensate for various printer speeds and feeds.|
Re: designing a program setup wizard tool for reprap November 30, 2009 11:21PM |
Re: designing a program setup wizard tool for reprap December 01, 2009 06:37AM |
Re: designing a program setup wizard tool for reprap December 01, 2009 08:21AM |
I also will try to find the minimum working temp where transition occurs for the abs plastic i am using. That means though, that I will need to have the user of the 3d_simple program run a sample test on the machine before using it. it would only take a few minutes but I would need an idea on humidity and room temp, for example i would show possibly 10 tubes each 15mm high and 5mm wide at several temps and ask the user what one printed ok.|
Re: designing a program setup wizard tool for reprap December 01, 2009 10:07AM |
Re: designing a program setup wizard tool for reprap December 01, 2009 04:34PM |
