AOI negative numbers bug
Posted by nophead
July 01, 2007 08:26AM
When AOI shows a negative number with more digits than will fit in the field allocated then it shifts it left so that the leading minus sign is not visible. If you watch carefully you can see it being drawn and then overwritten.
Something to be aware of if you are getting coordinates out of AOI manually like I am.
Re: AOI negative numbers bug
July 13, 2007 04:34AM
Hi Nophead,
Could you let me know which fields are giving you this behaviour? AOI uses a fairly small set of input fields, so it shouldn't be too hard to find the one(s) doing this and make sure they normally show the minus sign.
I've identified the fields in the Object property window, and the Object layout window. Are there any others which a causing you grief?
Cheers!
Nik
July 13, 2007 02:52PM
Hi Nik,
It was just the XYZ fields in the properties window that I noticed.
Regards, Chris
