Changing DC motor speed
December 17, 2009 06:49PM
Hello,
I have a DC motor extruder with Arudino Gen 2 electronics. My extruder is extruding a little too fast and I can't figure out how to slow it down. Can I do this in the host software or do I have to do it manually in the Arduino code itself.
Thanks,
Drummerboyx
Re: Changing DC motor speed
December 17, 2009 09:13PM
Extruder speed is an M command.
It is supplied by the reprap host / skeinforge software.
To add confussuin we have two sets of units
PWM and MM/minute. You will be PWM which has a range of 0-255.
(3000MM/Minute which is the reprap host software default may get converted to 255)
// Set speed of extruder
M108 S100;
// set temperature guard
M124 S020;
// start motor
M101;
regards
Stephen
December 18, 2009 04:10PM
How would I change it in the the host software? Is there a box in the preferences window?
December 18, 2009 09:25PM
Drummerboyx
I am sure you have my updated version of the firmware.
Anyway if you look in tested section of Gcode_interpreter.pde you will find
// Reprap Newest software (global.FiveD=false,extruder0.extruder speed 255)
Try setting the extrude speed to 210 on the extruder0 screen.
regards
Stephen
December 18, 2009 09:31PM
Ok. I get it. Thanks!
