Increasing java heap space in development version (eclipse)
Posted by Anonymous User
Hi All,
I can't build anything complex in the source version of REPRAP (just like it says in the release notes.)
How do I increase the Java heap space allocated for the source version of REPRAP?
This is done by passing arguments on the command line in the Jar version. Yes I am thinking about getting my hands dirty with the code, Host-8.1... is alive and well on my machine and builds everything I have thrown at it..
I have done what I think of as the obvious searches, but I guess not.
Thanks.
Best,
Dan
Re: Increasing java heap space in development version (eclipse)
July 10, 2007 03:48AM
Basically you need to pass an option argument of the form
-Xmx384M
to the java interpreter (where 384M means a maximum of 384 MBytes of RAM).
So:
(1) If you run the thing using "ant run", you can edit build-user.xml to add a jvmarg tag to the java task, something like
should be all you need.
(2) If you are running it inside Eclipse, you would use Run -> Run... and set up appropriate JVM arguments to a run task that do what you want.
(3) If you want to "just do it yourself" at the shell prompt, you can do something like
java -Xmx384M -jar ~/reprap/Reprap/jar/Reprap.jar
or use a similar longer command line that runs from the .class files directly.
Are you actually finding bugs that only show up in complex objects? I'm intrigued -- please tell us what they are! So far, I find I can happily tweak and test things with simple objects and not worry about RAM usage, and then package the result via host-package-release, unpack the resulting .zip file and run using the reprap.sh script to do anything "serious" with complex objects. But I can see why that might get annoying if you like to stay inside Eclipse and are working with bugs that you can't duplicate with simpler objects!
Jonathan
July 10, 2007 06:00PM
yay! it will be good for the host software to get some loving. once i get my darwin built, i'll also dive into the code. there are a ton of things i'd like to see done. personally, i think the 3d stuff is nice, but i'd love a 2D build view that can do exports to other formats (or a movie, or whatever.)
