Sanguino won't Compile
January 31, 2010 03:20AM
I installed arduino 18 and then used the patches from the sanguino download per the directions. If I use the Sanguino board definition, nothing will compile, it comes up with an error "
c:/program files/arduino-0018/hardware/tools/avr/bin/../lib/gcc/avr/4.3.3/../../../../avr/lib/avr5/crtm644p.osad smiley.init9+0x0): undefined reference to `main'"
I thought it might be java related, so I uninstalled java 6 and installed java 5.0 and that didn't change things.
I then downloaded arduino 11, but that won't open on my computer (running XP Pro sp3). After chasing this around for a many hours, I am at a roadblock. Any help that you can offer would be greatly appreciated.
EDIT *After more research, this is probably in the wrong forum.*
TIY,
J
Edited 1 time(s). Last edit at 01/31/2010 01:25PM by J-Dubs.
Re: Sanguino won't Compile
February 01, 2010 12:57AM
Try Arduino 17 to see if that works
I have not tried Arduino 18, nor did I know it was released, so try the older version first.
February 01, 2010 11:37AM
Awesome, thank you very much.
That's the way it always goes, I overthought it and went back too far.
-J
who am i?
I read it.
February 24, 2010 09:11PM
[twitter.com]
int main() {init();setup();for(;winking smileyloop();return 0;}
March 12, 2010 11:19AM
I had the same problem running Arduino 18. This link below solved my problem
[brewtroller.com]
Copy main.cpp from the arduino core directory to the sanguino core directory and every one is happy. "
March 17, 2010 02:28PM
Copying main.cpp worked for me. Thanks
June 05, 2010 12:42PM
The current release of the Sanguino definition files, Sanguino-0018r1_1_4.zip , appears to include the needed main.cpp file. Could those who encountered this issue please let us know what revision of the Sanguino files they were (or are) using?
Thanks!
Jonathan
