Extruder reversed
Posted by urbanzakapa
Extruder reversed
May 04, 2014 06:51PM
Guys,
I have a problem with my extruder and reverse settings in my pronterface. When I try to extrude the PLA, it start to pull it out from the extruder and when I click 'reverse' it extrudes the PLA. To make it simple, it likes both function is swapped. So, is there any way that I can make sure that both 'extrude' and 'reverse' settings works fine in which when I asks the machine to extrude, it extrudes and when I click 'reverse' it reverses.
Ramps 1.4
Prusa Mendel i2
Sprinter
Thanks
Re: Extruder reversed
May 06, 2014 06:00PM
Make sure your extruder stepper motor is wired up correctly. If it is, you can either reverse it in the firmware or reverse the wiring. Guide to stepper wiring (including reversing).
May 08, 2014 01:51PM
3dkarma
Thanks, works fine.
