How to delete objects from RepetierHost build plate?
October 21, 2014 08:52AM
I am getting familiar with Repetier Host, after 2 years of Pronterface.
I am not able to remove a previously loaded object, to load another object after the first one is printed.
So currently I close and restart the program.
I think there is a better way ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: How to delete objects from RepetierHost build plate?
October 22, 2014 04:35AM
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
October 22, 2014 07:11AM
Unfortunately:
I have no objects in the Object Placement window.
I only have my loaded object in the buildplate screen
So I can not select or delete
October 22, 2014 07:25AM
If you have no objects and are looking at the "Preview" tab then you have loaded a .gcode file and you can not delete anything from the build plate.
You must have the objects and regenerate the .gcode file.
Bob Morrison
October 22, 2014 07:53AM
Ahh,
so stopping and restarting the Host is the only way to print another object that I have sliced separately ?
This is reason to ask for a feature .......
October 22, 2014 08:02AM
No, do the following:
Bob Morrison
October 22, 2014 08:17AM
I will Try that !
Thanks Bob :-)
October 25, 2014 05:22AM
This works :-)
Thanks
Thomas
